| | Explorer stuck in endless loop? Explorer stuck in an endless loop of ending task and restarting, hindering your ability to use your computer? Well, the problem lies with a piece of spyware that cleverly disguises itself as a component from windows. TO REMOVE THIS: Boot your computer in normal mode. As soon as the explorer error happens the first time, press ctrl + alt + del and bring up the task manager. (or press ctrl + shift + esc) Go to the processes tab and END TASK on explorer.exe. If the dialogue says that explorer is restarting after you end task, press cancel to ensure explorer does not start back up. This will stabilize the system. Go to the application tab, and press new task. Type “C:” (without quotes) and click ok or press enter. When the window opens, press the word “computer” in the address bar. Click “uninstall or change a program” at the top, underneath the address bar. Arrange the programs however you feel best, but my suggestion would be by date and look around for the date nearest to the one on which you first noticed the problem. There will be a program called “Windows Safety/Security Alert” with a blank spot in the publisher column. That is the culprit. Double click it or select it and click uninstall. At the box that comes up, it will say “Your computer is about to restart, close all applications.” It will have an X in the top right corner and a close button in the bottom. CLICK NOTHING. Allow the computer to restart. If the problem was not resolved, try the above steps again, especially if there was an error the first time. If the program does not exist, look for anything to the affect with the word windows in the title and a blank publisher. There you have it, no more problems. **NOTE: This program usually comes bundled with another program called “Spy Locked.” This is a very tedious piece of spyware to remove and may require that you take the computer to a local computer repair center to have it removed, but you just saved yourself the trouble of reloading programs!** |
| | RE: Explorer stuck in endless loop? A simpler solution is to install SpyBot Search & Destroy, get the updates for it, then run it. If it finds it, but can not delete it, don't let SpyBot use it own form of safe mode, run it again in Vista's safe mode. "Mason" wrote: > Explorer stuck in an endless loop of ending task and restarting, hindering > your ability to use your computer? > > Well, the problem lies with a piece of spyware that cleverly disguises > itself as a component from windows. > > TO REMOVE THIS: > > Boot your computer in normal mode. As soon as the explorer error happens > the first time, press ctrl + alt + del and bring up the task manager. (or > press ctrl + shift + esc) > > Go to the processes tab and END TASK on explorer.exe. If the dialogue says > that explorer is restarting after you end task, press cancel to ensure > explorer does not start back up. This will stabilize the system. > > Go to the application tab, and press new task. Type “C:” (without quotes) > and click ok or press enter. When the window opens, press the word > “computer” in the address bar. > > Click “uninstall or change a program” at the top, underneath the address bar. > > Arrange the programs however you feel best, but my suggestion would be by > date and look around for the date nearest to the one on which you first > noticed the problem. > > There will be a program called “Windows Safety/Security Alert” with a blank > spot in the publisher column. That is the culprit. Double click it or > select it and click uninstall. > > At the box that comes up, it will say “Your computer is about to restart, > close all applications.” It will have an X in the top right corner and a > close button in the bottom. CLICK NOTHING. Allow the computer to restart. > > If the problem was not resolved, try the above steps again, especially if > there was an error the first time. If the program does not exist, look for > anything to the affect with the word windows in the title and a blank > publisher. > > There you have it, no more problems. > > **NOTE: This program usually comes bundled with another program called “Spy > Locked.” This is a very tedious piece of spyware to remove and may require > that you take the computer to a local computer repair center to have it > removed, but you just saved yourself the trouble of reloading programs!** > |
| | Re: Explorer stuck in endless loop? From a post by Malke >snip< Do the preparatory steps here: http://www.elephantboycomputers.com/...moving_Malware Include scanning with David Lipman's Multi_AV and follow instructions to do all scans in Safe Mode. http://www.elephantboycomputers.com/page2.html#Multi-AV - instructions http://pcdid.com/Multi_AV.htm - download Then do the specific steps here: http://www.elephantboycomputers.com/...itfraud_Trojan When all else fails, run HijackThis and post your log in one of the specialty forums listed at the first link above (not here, please). >end snip< -- Peter Please Reply to Newsgroup for the benefit of others Requests for assistance by email can not and will not be acknowledged. "Mason" <Mason@discussions.microsoft.com> wrote in message news:3495B9C6-4698-40C5-9C63-D9BAB2E7D1BA@microsoft.com... > Explorer stuck in an endless loop of ending task and restarting, hindering > your ability to use your computer? > > Well, the problem lies with a piece of spyware that cleverly disguises > itself as a component from windows. > > TO REMOVE THIS: > > Boot your computer in normal mode. As soon as the explorer error happens > the first time, press ctrl + alt + del and bring up the task manager. (or > press ctrl + shift + esc) > > Go to the processes tab and END TASK on explorer.exe. If the dialogue says > that explorer is restarting after you end task, press cancel to ensure > explorer does not start back up. This will stabilize the system. > > Go to the application tab, and press new task. Type “C:” (without quotes) > and click ok or press enter. When the window opens, press the word > “computer” in the address bar. > > Click “uninstall or change a program” at the top, underneath the address bar. > > Arrange the programs however you feel best, but my suggestion would be by > date and look around for the date nearest to the one on which you first > noticed the problem. > > There will be a program called “Windows Safety/Security Alert” with a blank > spot in the publisher column. That is the culprit. Double click it or > select it and click uninstall. > > At the box that comes up, it will say “Your computer is about to restart, > close all applications.” It will have an X in the top right corner and a > close button in the bottom. CLICK NOTHING. Allow the computer to restart. > > If the problem was not resolved, try the above steps again, especially if > there was an error the first time. If the program does not exist, look for > anything to the affect with the word windows in the title and a blank > publisher. > > There you have it, no more problems. > > **NOTE: This program usually comes bundled with another program called “Spy > Locked.” This is a very tedious piece of spyware to remove and may require > that you take the computer to a local computer repair center to have it > removed, but you just saved yourself the trouble of reloading programs!** > |
| | RE: Explorer stuck in endless loop? How is one to install spybot if explorer keeps restarting. This IS a simple solution. All it is is uninstalling ONE program. And I gave the steps to getting to the device manager without needing explorer to run... "Mick Murphy" wrote: > A simpler solution is to install SpyBot Search & Destroy, get the updates for > it, then run it. > If it finds it, but can not delete it, don't let SpyBot use it own form of > safe mode, run it again in Vista's safe mode. > > "Mason" wrote: > > > Explorer stuck in an endless loop of ending task and restarting, hindering > > your ability to use your computer? > > > > Well, the problem lies with a piece of spyware that cleverly disguises > > itself as a component from windows. > > > > TO REMOVE THIS: > > > > Boot your computer in normal mode. As soon as the explorer error happens > > the first time, press ctrl + alt + del and bring up the task manager. (or > > press ctrl + shift + esc) > > > > Go to the processes tab and END TASK on explorer.exe. If the dialogue says > > that explorer is restarting after you end task, press cancel to ensure > > explorer does not start back up. This will stabilize the system. > > > > Go to the application tab, and press new task. Type “C:” (without quotes) > > and click ok or press enter. When the window opens, press the word > > “computer” in the address bar. > > > > Click “uninstall or change a program” at the top, underneath the address bar. > > > > Arrange the programs however you feel best, but my suggestion would be by > > date and look around for the date nearest to the one on which you first > > noticed the problem. > > > > There will be a program called “Windows Safety/Security Alert” with a blank > > spot in the publisher column. That is the culprit. Double click it or > > select it and click uninstall. > > > > At the box that comes up, it will say “Your computer is about to restart, > > close all applications.” It will have an X in the top right corner and a > > close button in the bottom. CLICK NOTHING. Allow the computer to restart. > > > > If the problem was not resolved, try the above steps again, especially if > > there was an error the first time. If the program does not exist, look for > > anything to the affect with the word windows in the title and a blank > > publisher. > > > > There you have it, no more problems. > > > > **NOTE: This program usually comes bundled with another program called “Spy > > Locked.” This is a very tedious piece of spyware to remove and may require > > that you take the computer to a local computer repair center to have it > > removed, but you just saved yourself the trouble of reloading programs!** > > |
| | RE: Explorer stuck in endless loop? How is one to install spybot when Explorer doesn't work? The computer will continue to close spybot's window everytime windows explorer restarts. "Mick Murphy" wrote: > A simpler solution is to install SpyBot Search & Destroy, get the updates for > it, then run it. > If it finds it, but can not delete it, don't let SpyBot use it own form of > safe mode, run it again in Vista's safe mode. > > "Mason" wrote: > > > Explorer stuck in an endless loop of ending task and restarting, hindering > > your ability to use your computer? > > > > Well, the problem lies with a piece of spyware that cleverly disguises > > itself as a component from windows. > > > > TO REMOVE THIS: > > > > Boot your computer in normal mode. As soon as the explorer error happens > > the first time, press ctrl + alt + del and bring up the task manager. (or > > press ctrl + shift + esc) > > > > Go to the processes tab and END TASK on explorer.exe. If the dialogue says > > that explorer is restarting after you end task, press cancel to ensure > > explorer does not start back up. This will stabilize the system. > > > > Go to the application tab, and press new task. Type “C:” (without quotes) > > and click ok or press enter. When the window opens, press the word > > “computer” in the address bar. > > > > Click “uninstall or change a program” at the top, underneath the address bar. > > > > Arrange the programs however you feel best, but my suggestion would be by > > date and look around for the date nearest to the one on which you first > > noticed the problem. > > > > There will be a program called “Windows Safety/Security Alert” with a blank > > spot in the publisher column. That is the culprit. Double click it or > > select it and click uninstall. > > > > At the box that comes up, it will say “Your computer is about to restart, > > close all applications.” It will have an X in the top right corner and a > > close button in the bottom. CLICK NOTHING. Allow the computer to restart. > > > > If the problem was not resolved, try the above steps again, especially if > > there was an error the first time. If the program does not exist, look for > > anything to the affect with the word windows in the title and a blank > > publisher. > > > > There you have it, no more problems. > > > > **NOTE: This program usually comes bundled with another program called “Spy > > Locked.” This is a very tedious piece of spyware to remove and may require > > that you take the computer to a local computer repair center to have it > > removed, but you just saved yourself the trouble of reloading programs!** > > |
| | #6 (permalink) |
| | RE: Explorer stuck in endless loop? How can YOU do what you say if it is stuck in "your" endless loop? Wake up, boy "Mason" wrote: > Explorer stuck in an endless loop of ending task and restarting, hindering > your ability to use your computer? > > Well, the problem lies with a piece of spyware that cleverly disguises > itself as a component from windows. > > TO REMOVE THIS: > > Boot your computer in normal mode. As soon as the explorer error happens > the first time, press ctrl + alt + del and bring up the task manager. (or > press ctrl + shift + esc) > > Go to the processes tab and END TASK on explorer.exe. If the dialogue says > that explorer is restarting after you end task, press cancel to ensure > explorer does not start back up. This will stabilize the system. > > Go to the application tab, and press new task. Type “C:” (without quotes) > and click ok or press enter. When the window opens, press the word > “computer” in the address bar. > > Click “uninstall or change a program” at the top, underneath the address bar. > > Arrange the programs however you feel best, but my suggestion would be by > date and look around for the date nearest to the one on which you first > noticed the problem. > > There will be a program called “Windows Safety/Security Alert” with a blank > spot in the publisher column. That is the culprit. Double click it or > select it and click uninstall. > > At the box that comes up, it will say “Your computer is about to restart, > close all applications.” It will have an X in the top right corner and a > close button in the bottom. CLICK NOTHING. Allow the computer to restart. > > If the problem was not resolved, try the above steps again, especially if > there was an error the first time. If the program does not exist, look for > anything to the affect with the word windows in the title and a blank > publisher. > > There you have it, no more problems. > > **NOTE: This program usually comes bundled with another program called “Spy > Locked.” This is a very tedious piece of spyware to remove and may require > that you take the computer to a local computer repair center to have it > removed, but you just saved yourself the trouble of reloading programs!** > |
| | #7 (permalink) |
| | RE: Explorer stuck in endless loop? Did YOU read what I posted at all? I gave the instructions to allow them to get to the uninstall panel WITHOUT it causing any errors. You wakeup. "Mick Murphy" wrote: > How can YOU do what you say if it is stuck in "your" endless loop? > Wake up, boy > > "Mason" wrote: > > > Explorer stuck in an endless loop of ending task and restarting, hindering > > your ability to use your computer? > > > > Well, the problem lies with a piece of spyware that cleverly disguises > > itself as a component from windows. > > > > TO REMOVE THIS: > > > > Boot your computer in normal mode. As soon as the explorer error happens > > the first time, press ctrl + alt + del and bring up the task manager. (or > > press ctrl + shift + esc) > > > > Go to the processes tab and END TASK on explorer.exe. If the dialogue says > > that explorer is restarting after you end task, press cancel to ensure > > explorer does not start back up. This will stabilize the system. > > > > Go to the application tab, and press new task. Type “C:” (without quotes) > > and click ok or press enter. When the window opens, press the word > > “computer” in the address bar. > > > > Click “uninstall or change a program” at the top, underneath the address bar. > > > > Arrange the programs however you feel best, but my suggestion would be by > > date and look around for the date nearest to the one on which you first > > noticed the problem. > > > > There will be a program called “Windows Safety/Security Alert” with a blank > > spot in the publisher column. That is the culprit. Double click it or > > select it and click uninstall. > > > > At the box that comes up, it will say “Your computer is about to restart, > > close all applications.” It will have an X in the top right corner and a > > close button in the bottom. CLICK NOTHING. Allow the computer to restart. > > > > If the problem was not resolved, try the above steps again, especially if > > there was an error the first time. If the program does not exist, look for > > anything to the affect with the word windows in the title and a blank > > publisher. > > > > There you have it, no more problems. > > > > **NOTE: This program usually comes bundled with another program called “Spy > > Locked.” This is a very tedious piece of spyware to remove and may require > > that you take the computer to a local computer repair center to have it > > removed, but you just saved yourself the trouble of reloading programs!** > > |
| Endless loop | Vista General | |||
| Vista SP1 prerequis3te 3 endless boot loop | Vista installation & setup | |||
| Vista SP1 RC uninstall: Endless loop - help! | Vista installation & setup | |||
| Explorer crashing in endless loop | Vista General | |||
| ENDLESS REBOOT LOOP WHEN INSTALLING VISTA | Vista General | |||
