| | DVD Maker sound & picture out of snyc I don't know if anyone else had had this problem, but I somewhat successfully burned movies to DVD using the Windows DVD Maker. Only problem is the sound and picture are out of sync. I hear the sound first, then the picture to match is about 2-3 seconds delayed. Anyone else had and/or solved this issue? I've already wasted 3 DVDs thanks to the wonderful "help" at HP. Vista was preloaded on my notebook so I don't think I can get support from Microsoft & HP doesn't really have any knowledge about Windows products. Any help would be much appreciated! |
| | Re: DVD Maker sound & picture out of snyc I had the same problem when I had a slower cpu. What are you recording from? "kschultz44" <kschultz44@discussions.microsoft.com> wrote in message news:630B7CA8-41DA-4793-8D74-EC96BD47ED12@microsoft.com... >I don't know if anyone else had had this problem, but I somewhat >successfully > burned movies to DVD using the Windows DVD Maker. Only problem is the > sound > and picture are out of sync. I hear the sound first, then the picture to > match is about 2-3 seconds delayed. Anyone else had and/or solved this > issue? > > I've already wasted 3 DVDs thanks to the wonderful "help" at HP. Vista > was > preloaded on my notebook so I don't think I can get support from Microsoft > & > HP doesn't really have any knowledge about Windows products. Any help > would > be much appreciated! |
| | Re: DVD Maker sound & picture out of snyc Directly from files on my hardrive. And this is a new computer so it's not slow, though I have managed to already use 94% of the system storage. I converted a dvr-ms file into mpg then tried to burn it to dvd. Essentially I'm trying to get the files off my computer to free up my hardrive. Plus it's nice to be able to play the movies anywhere on DVD. "John Barnes" wrote: > I had the same problem when I had a slower cpu. What are you recording > from? |
| | Re: DVD Maker sound & picture out of snyc Have you tried playing your mpg file to see if it has the problem. Your conversion file may be the source of the problem. Many new computers have slow cpu's and also almost all programs will run on only one core of a dual core system and are only as fast as one core runs, many times slower than a fast single core. "kschultz44" <kschultz44@discussions.microsoft.com> wrote in message news:04C74D60-D2D7-4BF3-A075-117B4806A988@microsoft.com... > Directly from files on my hardrive. And this is a new computer so it's > not > slow, though I have managed to already use 94% of the system storage. I > converted a dvr-ms file into mpg then tried to burn it to dvd. > Essentially > I'm trying to get the files off my computer to free up my hardrive. Plus > it's nice to be able to play the movies anywhere on DVD. > > "John Barnes" wrote: > >> I had the same problem when I had a slower cpu. What are you recording >> from? |
| | Re: DVD Maker sound & picture out of snyc That's what I did first. I checked the files and they played perfectly. And thanks for the rest of the info on the single vs dual core system. Any more thoughts of anything I might check? "John Barnes" wrote: > Have you tried playing your mpg file to see if it has the problem. Your > conversion file may be the source of the problem. Many new computers have > slow cpu's and also almost all programs will run on only one core of a dual > core system and are only as fast as one core runs, many times slower than a > fast single core. |
| | #6 (permalink) |
| | Re: DVD Maker sound & picture out of snyc So I just tried to burn the same files using Roxio and the DVD came out fine. The sound & picture matched right up as it should. There's just something wrong in the Windows DVD Maker software that causes this issue. I like the menu options on the Windows software much more than the Roxio software so I'd really like to figure out some way to make it work. |
| | #7 (permalink) |
| | Re: DVD Maker sound & picture out of snyc You might try posting in the newsgroup for the DVD Maker maybe the microsoft.public.windows.vista.music_pictures_video "kschultz44" <kschultz44@discussions.microsoft.com> wrote in message news:21EB7004-E9C4-4D3B-A56E-5AC58C434C08@microsoft.com... > So I just tried to burn the same files using Roxio and the DVD came out > fine. > The sound & picture matched right up as it should. There's just something > wrong in the Windows DVD Maker software that causes this issue. I like > the > menu options on the Windows software much more than the Roxio software so > I'd > really like to figure out some way to make it work. |
| | #8 (permalink) |
| | Re: DVD Maker sound & picture out of snyc Anyone else? |
| | #9 (permalink) |
| | Re: DVD Maker sound & picture out of snyc "kschultz44" <kschultz44@discussions.microsoft.com> wrote in message news:96964D8C-CC9E-4A31-8179-C98D3D2CF0C9@microsoft.com... > Anyone else? well I had sound out of syn when playing dvd's in media player, I had corrupted mpg decoders, but vista has no easy way to fix that, no easy way to assign codecs used and make registry changes for you. I tried so many things until I corrupted my registry enough that I had to do a clean install of vista. The good news is the dvd players great now, not out of sync. The bad news is, Vista says my cd key is already in use and won't activate automatically online so I need to call soon and spend 20 minutes playing the recite the number game with some human to re-activate a legal copy that I just reloaded to fix a problem that the OS shouldn't have developed to begin with. ![]() Ah technology, don't you just love it? AnthonyR. |
| Win DVD Maker: Dimenished Picture Quality of DVD | Vista music pictures video | |||
| Picture Duration in Movie Maker | Vista music pictures video | |||
| DVD Maker sound & picture out of snyc | Vista music pictures video | |||
| Windows Movie Maker - still picture | Vista music pictures video | |||
| Vista DVD Maker - Cut off Picture on TV | Vista General | |||
