| | Task manager problem Hi all! Somehow the Task Manager in my Vista Home Premium has been disabled. When i press Ctrl, Alt, Del it doesn't appear as an option. I cannot find where it is re-enabled. Can someone please help me TIA Clive In Kent (GB) |
| | Re: Task manager problem It opens a shut down page and Task Manager is the bottom choice. "Clive In Kent .com>" <cliverholden@hotmail<remove> wrote in message news:129589E8-39AE-4617-9495-70D54639F551@microsoft.com... > Hi all! > > Somehow the Task Manager in my Vista Home Premium has been disabled. When > i press Ctrl, Alt, Del it doesn't appear as an option. I cannot find where > it is re-enabled. Can someone please help me > > TIA > > Clive In Kent (GB) > |
| | Re: Task manager problem Nope its not there anymore Clive In Kent "Ian" <igb123@talktalk.net> wrote in message news:0EFF0917-C02E-41D7-B0A3-9D05ACB271CD@microsoft.com... > It opens a shut down page and Task Manager is the bottom choice. > > > "Clive In Kent .com>" <cliverholden@hotmail<remove> wrote in message > news:129589E8-39AE-4617-9495-70D54639F551@microsoft.com... >> Hi all! >> >> Somehow the Task Manager in my Vista Home Premium has been disabled. When >> i press Ctrl, Alt, Del it doesn't appear as an option. I cannot find >> where it is re-enabled. Can someone please help me >> >> TIA >> >> Clive In Kent (GB) >> > |
| | Re: Task manager problem You can right click the Taskbar to get to Task Manager. -- I Bleed Blue and Gold GO BEARS! "Clive In Kent .com>" <cliverholden@hotmail<remove> wrote in message news:129589E8-39AE-4617-9495-70D54639F551@microsoft.com... > Hi all! > > Somehow the Task Manager in my Vista Home Premium has been disabled. When i > press Ctrl, Alt, Del it doesn't appear as an option. I cannot find where it is > re-enabled. Can someone please help me > > TIA > > Clive In Kent (GB) |
| | Re: Task manager problem Its been disabled!!! Clive In Kent (GB) "Cal Bear '66" <xxx@xxx.org> wrote in message news:664F2F96-F504-4E4A-B289-224BADB7F292@microsoft.com... > You can right click the Taskbar to get to Task Manager. > > -- > I Bleed Blue and Gold > GO BEARS! > > > "Clive In Kent .com>" <cliverholden@hotmail<remove> wrote in message > news:129589E8-39AE-4617-9495-70D54639F551@microsoft.com... >> Hi all! >> >> Somehow the Task Manager in my Vista Home Premium has been disabled. When >> i press Ctrl, Alt, Del it doesn't appear as an option. I cannot find >> where it is re-enabled. Can someone please help me >> >> TIA >> >> Clive In Kent (GB) > > |
| | #6 (permalink) |
| | Re: Task manager problem From Help and Support: If Task Manager has been disabled, you can re-enable it if you have administrator privileges on the computer. To enable Task Manager on a computer running Windows Vista Home Basic or Windows Vista Home Premium This procedure requires you to edit the registry. An incorrect change to your computer's registry could render your computer inoperable. We strongly recommend that you back up the registry before making any changes. For more information, see Back up the registry. Click to open Registry Editor.? If you are prompted for an administrator password or confirmation, type the password or provide confirmation. Navigate to the following location: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies Double-click System, double-click DisableTaskMgr, change Value data to 0, and then click OK. To enable task Manager on a computer running other editions of Windows Vista Click the Start button , type gpedit.msc in the search box, and then press ENTER. Under User Configuration, double-click Administrative Templates. Double-click System, and then click Crtl+Alt+Del Options. Double-click Remove Task Manager, click Disabled, and then click OK. Note If the Remove Task Manager properties appear dimmed, your network administrator has prevented you from changing these settings. Contact your network administrator to have Task Manager enabled. -- I Bleed Blue and Gold GO BEARS! "Clive In Kent .com>" <cliverholden@hotmail<remove> wrote in message news:29327D91-BAAE-4B3F-AD37-BE45C0CAD8AC@microsoft.com... > Its been disabled!!! > > Clive In Kent (GB) > "Cal Bear '66" <xxx@xxx.org> wrote in message > news:664F2F96-F504-4E4A-B289-224BADB7F292@microsoft.com... >> You can right click the Taskbar to get to Task Manager. >> >> -- >> I Bleed Blue and Gold >> GO BEARS! >> >> >> "Clive In Kent .com>" <cliverholden@hotmail<remove> wrote in message >> news:129589E8-39AE-4617-9495-70D54639F551@microsoft.com... >>> Hi all! >>> >>> Somehow the Task Manager in my Vista Home Premium has been disabled. When i >>> press Ctrl, Alt, Del it doesn't appear as an option. I cannot find where it >>> is re-enabled. Can someone please help me >>> >>> TIA >>> >>> Clive In Kent (GB) >> >> > |
| | #7 (permalink) |
| | Re: Task manager problem found these things to try.... 1. try Control-Shift-Esc 2. Try running the System File Checker. This will make sure that all the files Windows needs are present and not corrupted. You can do this by clicking Start>Run and then typing: sfc /scannow then clicking OK. Make sure there is a space between 'sfc' and '/scannow'. You will need your Windows CD if any files need to be replaced. 3. Could be caused by a virus http://library-cafe.com/article/how-...rus-515-1.html 4. Are you getting an error message? http://support.microsoft.com/kb/555480 "Clive In Kent.com>" <cliverholden@hotmail<remove> wrote in message news:29327D91-BAAE-4B3F-AD37-BE45C0CAD8AC@microsoft.com... > Its been disabled!!! > > Clive In Kent (GB) > "Cal Bear '66" <xxx@xxx.org> wrote in message > news:664F2F96-F504-4E4A-B289-224BADB7F292@microsoft.com... >> You can right click the Taskbar to get to Task Manager. >> >> -- >> I Bleed Blue and Gold >> GO BEARS! >> >> >> "Clive In Kent .com>" <cliverholden@hotmail<remove> wrote in message >> news:129589E8-39AE-4617-9495-70D54639F551@microsoft.com... >>> Hi all! >>> >>> Somehow the Task Manager in my Vista Home Premium has been disabled. >>> When i press Ctrl, Alt, Del it doesn't appear as an option. I cannot >>> find where it is re-enabled. Can someone please help me >>> >>> TIA >>> >>> Clive In Kent (GB) >> >> > |
| | #8 (permalink) |
| | Re: Task manager problem Thanks Cal I looked on help & support and ms support website but couldn't find that!! Googled and found a cure now Cheers Clive In Kent (GB) "Cal Bear '66" <xxx@xxx.org> wrote in message news:B3E11960-C2FE-4972-A779-1DFF14E67B87@microsoft.com... > From Help and Support: > > > If Task Manager has been disabled, you can re-enable it if you have > administrator privileges on the computer. > > To enable Task Manager on a computer running Windows Vista Home Basic or > Windows Vista Home Premium > This procedure requires you to edit the registry. An incorrect change to > your computer's registry could render your computer inoperable. We > strongly recommend that you back up the registry before making any > changes. For more information, see Back up the registry. > > Click to open Registry Editor.? If you are prompted for an administrator > password or confirmation, type the password or provide confirmation. > > Navigate to the following location: > HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies > > Double-click System, double-click DisableTaskMgr, change Value data to 0, > and then click OK. > > To enable task Manager on a computer running other editions of Windows > Vista > Click the Start button , type gpedit.msc in the search box, and then > press ENTER. > > Under User Configuration, double-click Administrative Templates. > > Double-click System, and then click Crtl+Alt+Del Options. > > Double-click Remove Task Manager, click Disabled, and then click OK. > > Note > If the Remove Task Manager properties appear dimmed, your network > administrator has prevented you from changing these settings. Contact your > network administrator to have Task Manager enabled. > > > -- > I Bleed Blue and Gold > GO BEARS! > > > "Clive In Kent .com>" <cliverholden@hotmail<remove> wrote in message > news:29327D91-BAAE-4B3F-AD37-BE45C0CAD8AC@microsoft.com... >> Its been disabled!!! >> >> Clive In Kent (GB) >> "Cal Bear '66" <xxx@xxx.org> wrote in message >> news:664F2F96-F504-4E4A-B289-224BADB7F292@microsoft.com... >>> You can right click the Taskbar to get to Task Manager. >>> >>> -- >>> I Bleed Blue and Gold >>> GO BEARS! >>> >>> >>> "Clive In Kent .com>" <cliverholden@hotmail<remove> wrote in message >>> news:129589E8-39AE-4617-9495-70D54639F551@microsoft.com... >>>> Hi all! >>>> >>>> Somehow the Task Manager in my Vista Home Premium has been disabled. >>>> When i press Ctrl, Alt, Del it doesn't appear as an option. I cannot >>>> find where it is re-enabled. Can someone please help me >>>> >>>> TIA >>>> >>>> Clive In Kent (GB) >>> >>> >> > > |
| | #9 (permalink) |
| | Re: Task manager problem Thanks Dave Googled & found a cure now Clive In Kent (GB) "Dave" <dave@beepbeep.com> wrote in message news:%235reL4xwHHA.4572@TK2MSFTNGP02.phx.gbl... > found these things to try.... > > 1. try Control-Shift-Esc > > 2. Try running the System File Checker. This will make sure that all the > files Windows needs are present and not corrupted. You can do this by > clicking Start>Run and then typing: > sfc /scannow > then clicking OK. Make sure there is a space between 'sfc' and '/scannow'. > You will need your Windows CD if any files need to be replaced. > > 3. Could be caused by a virus > http://library-cafe.com/article/how-...rus-515-1.html > > 4. Are you getting an error message? > http://support.microsoft.com/kb/555480 > > > > > "Clive In Kent.com>" <cliverholden@hotmail<remove> wrote in message > news:29327D91-BAAE-4B3F-AD37-BE45C0CAD8AC@microsoft.com... >> Its been disabled!!! >> >> Clive In Kent (GB) >> "Cal Bear '66" <xxx@xxx.org> wrote in message >> news:664F2F96-F504-4E4A-B289-224BADB7F292@microsoft.com... >>> You can right click the Taskbar to get to Task Manager. >>> >>> -- >>> I Bleed Blue and Gold >>> GO BEARS! >>> >>> >>> "Clive In Kent .com>" <cliverholden@hotmail<remove> wrote in message >>> news:129589E8-39AE-4617-9495-70D54639F551@microsoft.com... >>>> Hi all! >>>> >>>> Somehow the Task Manager in my Vista Home Premium has been disabled. >>>> When i press Ctrl, Alt, Del it doesn't appear as an option. I cannot >>>> find where it is re-enabled. Can someone please help me >>>> >>>> TIA >>>> >>>> Clive In Kent (GB) >>> >>> >> |
| Task manager and language bar problem!! | General Discussion | |||
| Vista *32 task manager problem? | General Discussion | |||
| task manager problem | Vista performance & maintenance | |||
| Task Manager Problem. | Vista performance & maintenance | |||
| task manager problem | Vista account administration | |||
