Vista - Remote Desktop Connection - Data Execution Prevention - Failure
Old 07-11-2007   #1 (permalink)
Mike from Connecticut (CEA)
I have just upgreaded to VISTA Enterprise, from XP SP2. I can no longer
connect to other computers (my servers) using Remote Desktop Connection. I
get a message about 'Data Execution Prevention'. I follow the steps and have
'Remote Desktop Connection' checked so that it will not be protected by Data
Execution Prevention. No change, it still will not connect. I can ping the
devices, open any shares off them, etc..
Any clues on what is wrong?
Solved Data Execution Prevention System Security
Solved Data Execution Prevention General Discussion
Data execution prevention System Security
data execution prevention Vista mail
data execution prevention help Vista security
