| | Display problems Hi All I have a wierd problem with Vista or maybe display drivers. System is an intel E6700, 2G RAM, NX8500GT video card, Vista Home premium running a 24" Delll LCD on VGA. Problem is about every 10th boot the system boots up ok but the desktop is all wrong, imagine splitting the desktop into two havles left and right and then displaying the halves in the opposite half, the system works fine still, the mouse runs off the edge of the monitor and appears on the other half etc, you can shut the machine down and reboot and all is well. I have done all of the vista updates and have downloaded both the latest drivers from my card manufacturer and from nvidia but nothing changes, any help would be good......... m4r..confussed |
| | Re: Display problems "m4r" <hawk69@iprimus.com.au> wrote in message news:F0B622DA-DDDD-41AC-B6DE-DF66E1A01800@microsoft.com... > Hi All > > I have a wierd problem with Vista or maybe display drivers. System is an > intel E6700, 2G RAM, NX8500GT video card, Vista Home premium running a 24" > Delll LCD on VGA. Problem is about every 10th boot the system boots up ok > but the desktop is all wrong, imagine splitting the desktop into two > havles left and right and then displaying the halves in the opposite half, > the system works fine still, the mouse runs off the edge of the monitor > and appears on the other half etc, you can shut the machine down and > reboot and all is well. I have done all of the vista updates and have > downloaded both the latest drivers from my card manufacturer and from > nvidia but nothing changes, any help would be good......... > > m4r..confussed Sounds like a video card driver issue. Do you have any down-level versions of the video card driver that you can reinstall and see if the same thing occurs? Lang |
| Display Problems | Vista performance & maintenance | |||
| display problems | Vista General | |||
| Display problems | Graphic cards | |||
| Display problems | Vista music pictures video | |||
| Display Problems???? HELP | Vista General | |||
