Vista - Help, Vista's firewall started to work with outbound traffic, and I don't know how to stop it!!!!!
Old 07-12-2007   #1 (permalink)
Juan I. Cahis
Dear friends:
I don't know why, but as a result of this, my computer has become very
slow. How can I return to the standard firewall inbound traffic check
only?
Thanks
Juan I. Cahis
Santiago de Chile (South America)
Note: Please forgive me for my bad English, I am trying to improve it!
Old 07-12-2007   #2 (permalink)
Richard Urban
Re: Help, Vista's firewall started to work with outbound traffic, and I don't know how to stop it!!!!!
Did you install Vista Firewall Control?
Regards,
Richard Urban
"Juan I. Cahis" <jiclbchSINBASURA@attglobal.net> wrote in message
news:sgec93134a7079s9vm10fdocj3tl1g0tnt@4ax.com...
Dear friends:
only?
Thanks
Juan I. Cahis
Old 07-12-2007   #3 (permalink)
Juan I. Cahis
Is this a free application recommended in the last issue of PC World
to control Vista's firewall? If it is, yes, but I didn't have the time
to use it.
Thanks
Juan I. Cahis
Old 07-12-2007   #4 (permalink)
Richard Urban
Vista Firewall Control will ask you to approve outbound traffic. That is
what it is all about. Just say "allow all", or allow always and you will not
be bothered for that program again.
Regards,
Richard Urban
news:0mhc931m01dq71uuj02mncueapt2l3v1hs@4ax.com...
to use it.
Thanks
Juan I. Cahis
Old 07-12-2007   #5 (permalink)
Ian
You can set by going Control Panel/Security Centre and chose the firewall
reset link.
Dear friends:
only?
Thanks
Juan I. Cahis
Old 07-12-2007   #6 (permalink)
Mr. Arnold
Dear friends:
What are you talking about?
A firewall always works with outbound traffic. The programs running on the
computer that communicate over the Internet to another program are always
sending outbound traffic.
only?
It sounds to me like you have malware running on the machine that's sending
dubious outbound traffic, it's slowing the machine down, you need to find it
and remove the malware.
Old 07-12-2007   #7 (permalink)
Juan I. Cahis
Thanks a lot, Richard.
I solved the problem uninstalling that program, *AND* restoring the
system to the state immediately previous to its installation.
The Firewall returned to its "inbound traffic only" status, like
originally in Vista or XP.
>what it is all about. Just say "allow all", or allow always and you willnot
Thanks
Juan I. Cahis
Old 07-12-2007   #8 (permalink)
Juan I. Cahis
Sorry Arnold, but you are wrong. WinXP firewall checks, by design,
inbound traffic only, as also does Vista firewall in its default
configuration, as set by Microsoft.
>Dear friends:
>only?
Thanks
Juan I. Cahis
Old 07-13-2007   #9 (permalink)
Mick Murphy
Juan, you are wrong. Go to control Panel, security, Windoes Firewall> Allow a
program to go out.
And XP was like it too.
> >Dear friends:
> >only?
> Thanks
> Juan I. Cahis
Old 07-13-2007   #10 (permalink)
Mr. Arnold
news:lljd93lq60ng7k1grm18s7upm2mt9ruq6t@4ax.com...
You want to show me where I said anything about the FW stopping outbound
traffic.
The FW doesn't stop outbound traffic by design. A FW by default stops all
unsolicited inbound traffic by design. If a FW is to stop outbound traffic,
if it has those capabilities, then rules have to be set to stop the
outbound, because by design, there are no default rules for a FW to stop
outbound traffic.
>Dear friends:
>only?
>it
Thanks
Juan I. Cahis
Firewall message - Wudfhost.exe attempting outbound traffic - to IP 67.135.105.130... Vista performance & maintenance
Windows Firewalls - blocking outbound traffic - best set-up? Vista performance & maintenance
Firewall blocks outbound traffic even if outbound rule exists Vista security
Vista firewall not blocking outbound traffic despite explicit rules to do so Vista security
Firewall Rules - Outbound Vista security
