Vista Tutorial - Major problem - vista won't boot, even in safe mode
Old 07-12-2007   #1 (permalink)
Shaun
Guest
Having a problem here. I am away from home for a few weeks, so I don't have
my Vista cd's with me.
I noticed Vista installed a bunch of updates throughout the day today (maybe
10). I got a notification saying not all updates were installed. I
attempted to install the 2 that hadn't installed. There was an error
installing, so I decided to reboot.
Now when I try to boot, everything looks normal, I get the first Vista
screen. Then my display (I have the system hooked directly to a TV through
S-video) briefly flickers off as if the computer turned off. Then for a
moment I see the mouse icon, which I can control. The whole system then
restarts every time. It will go through this whole process repeatedly and
Vista itself never actually boots. Even when I try to start in safe mode,
the same thing happens.
As I said, I won't have my vista cd's for a few weeks. Is there anything at
all I can do, or do I have to wait to try to "repair windows" with the vista
disc? Thanks for any suggestions.
Old 07-13-2007   #2 (permalink)
Spenceation
Guest
RE: Major problem - vista won't boot, even in safe mode
If you don't actually boot up completely you should try Last Known Good
Configuration, at the same place as Safe Mode. If that doesn't work, try Safe
Mode with Command Prompt and see if that will atleast boot up. Other than
that, you will need to wait for the cd to do a Startup Repair or System
Restore.
Old 07-13-2007   #3 (permalink)
Shaun
Guest
Thanks for the suggestions, but neither of those methods booted either.. Is
there any way to download any type of "windows repair" bootable CD or
anything like that?
Thanks.
> Restore.
Old 07-13-2007   #4 (permalink)
Spenceation
Guest
Unless you can find a third party dvd image, there isn't. If you have someone
else's copy of Vista or even a demo cd you can do it. It doesn't have to be
your own disc.
> anything like that?
> Thanks.
> > Restore.
Old 08-30-2008   #5 (permalink)
PcMed365
Guest
Re: Major problem - vista won't boot, even in safe mode
What kind of computer do you have?
Shaun;191959 Wrote:
> have
> (maybe
> through
> a
> then
> and
> mode,
> anything at
> vista
After 2 Clean re-installs vista still won boot to normal mode but will boot to safe M General Discussion
Vista will only boot to safe mode Vista General
Can't boot vista or start in safe mode Vista General
vista only boot to safe mode but not normal mode Vista General
Vista will not boot - not even in Safe Mode Vista General
