Windows integration
Register your program's sounds in the Windows Sounds registry. Doing so
allows the Windows Vista volume mixer to add a slider for your program.
Register your program's custom sound events. Doing so allows the Windows
Sound control panel item to display them. Create the following key for each
custom sound event: HKEY_CURRENT_USER | AppEvents | Event Labels | EventName
= Event Name.
http://msdn2.microsoft.com/en-us/library/aa511278.aspx
Gistcheckin
"fw" wrote:
> My question is where exactly to make the change.
> "Gistcheckin" wrote:
> > Try disabling AV and Firewall software which is known to block Registry
> > Changes. Or, go into Safe Mode and make the changes.
> > Gistcheckin
> > "fw" wrote:
> > > Vista introduced the feature known as volume mixer where each application (in
> > > this case IE7) has a volume control slider bar compounded to the universal
> > > device volume control. By default the application volume control bar is in
> > > par with device control bar. Because my earphone is quite sensitive, even the
> > > lowest notch (1) of device volume is very loud, so I have to adjust each
> > > application volume to ~5% of device volume (i.e. when device volume is 100,
> > > application volume is 5). Volume mixer remembers the setting so I only have
> > > to do the adjustment once for each application. This works fine for most apps
> > > such as WMP etc. But for IE7, I found my setting is not remembered. So I have
> > > to adjust the volume everytime.
> > > Is there anywhere (registry etc.) I can manually specify volume setting for
> > > IE7?
