| | Old help WinHlp32.exe Hello, I clicked on the help button of a perfectly good freeware program, and Vista said the format of the help file is no longer approved by the higher authorities. There was a link to 3 screenfuls of stuff that says you can download WinHlp32.exe, but the Continue button just sends you to a load of crap to download stuff to validate Windows. I've just bought the computer from Dell (stupid idea, will never do that again), so it should be validated already, bearing in mind the links between the 2 suppliers (all that publicity by Dell for V*sta). Now, I just want to use my computer. Regards |
| | Re: Old help WinHlp32.exe http://support.microsoft.com/kb/917607 The Windows Help is no longer included ..... http://go.microsoft.com/fwlink/?LinkID=82148 Windows Download for Help Program "Christopher R. Lee" <nobody@wanadoo.fr> wrote in message news:%23gbNr%236xHHA.5276@TK2MSFTNGP02.phx.gbl... > Hello, > > I clicked on the help button of a perfectly good freeware program, and > Vista said the format of the help file is no longer approved by the higher > authorities. There was a link to 3 screenfuls of stuff that says you can > download WinHlp32.exe, but the Continue button just sends you to a load of > crap to download stuff to validate Windows. > > I've just bought the computer from Dell (stupid idea, will never do that > again), so it should be validated already, bearing in mind the links > between the 2 suppliers (all that publicity by Dell for V*sta). > > Now, I just want to use my computer. > > Regards > |
| | RE: Old help WinHlp32.exe The validation is required to get anything extra from Microsoft. It really is no big deal since it is just checking to see if you have a vaild version of Windows. Just follow the instructions. It only take a few seconds. -- Paul "Christopher R. Lee" wrote: > Hello, > > I clicked on the help button of a perfectly good freeware program, and Vista > said the format of the help file is no longer approved by the higher > authorities. There was a link to 3 screenfuls of stuff that says you can > download WinHlp32.exe, but the Continue button just sends you to a load of > crap to download stuff to validate Windows. > > I've just bought the computer from Dell (stupid idea, will never do that > again), so it should be validated already, bearing in mind the links between > the 2 suppliers (all that publicity by Dell for V*sta). > > Now, I just want to use my computer. > > Regards > > |
| WinHlp32.exe | Vista General | |||
| winhlp32.exe | General Discussion | |||
| winhlp32.exe | Vista General | |||
| Winhlp32.exe *STILL* MIA! | Vista General | |||
| Winhlp32.exe | Vista General | |||
