Vista - Battery Metre
Old 07-20-2007   #1 (permalink)
Bob from down under
Battery Metre
My Toshiba laptop does not show the battery meter when running on battery,
where do you turn it on from in Vista?
Old 07-20-2007   #2 (permalink)
Quaker
RE: Battery Metre
Right click on the task bar and select property option.
In the notification panel, you can check the always display icons like
battery.
That may works.
battery General Discussion
battery Vista performance & maintenance
Battery or no battery ? Vista performance & maintenance
Volume metre? Vista hardware & devices
Laptop battery issue ??battery calibration?? General Discussion
