RB
Vista - System Repair-Vista Ultimate
07-20-2007   #1
Brendan
Admittedly I have been over using SR of late due to a few problems which I
shall not bore you with.
My problem now is that SR will not restore to ANY restore points. My
instinct is to do a Repair Restore from my installation DVD. Any comments or
suggestions please before I commit?
07-20-2007   #2
Mick Murphy
RE: System Repair-Vista Ultimate
Touch wood, I have not had to use SR in Vista yet.
In XP, I used it very sparingly, as the system was never in top working
order after using it. Errors would become more common. I only used it as a
stop gap measure until I had the time to do a clean install.
And I will do the same with Vista.
The advice on a lot of posts here is that SR is the be all and end all to
repair everything. The problem should be solved instead of falling back on SR
all the time.
Just my 2 cents worth!
07-20-2007   #3
Brendan
Re: System Repair-Vista Ultimate
Thanks Mick- but the thing is I did use it, rightly or not and I am still in
the bind. The entire system is now a bit wobbly. I have tried 'start repair'
from the disc- answer 'no probs' What are my options now?
"Mick Murphy" <MickMurphy@discussions.microsoft.com> wrote in message
news:20630587-C274-4C56-B695-751D5438000F@microsoft.com...
> SR
> all the time.
>> I
>> or
07-20-2007   #4
Mick Murphy
You want to do a clean istall.
1 Back up all your data; you will lose all docs and extra programs you have
installed.
2 Disconnect all peripherals, except mouse, monitor and keyboard.
3 Insert the Vista DVD in Drive, reboot and set bios to boot from CD/DVD
Drive first.
4 When you are reinstalling, delete the partition that Vista is already on,
formatt your hard drive, the whole lot, or a partition size that you want
formatted.
5 When you are installing, leave the Admin name and Password BLANK. Just put
in your user name right at the end of installation.
> > SR
> > all the time.
> >> I
> >> or
07-21-2007   #5
Chad Harris
Re: System Repair-Vista Ultimate/Many More Untried Options
Brendan --
I respectfully disagree with Mr. Murphy. You have a number of MSFT endorsed
options besides Startup Repair in Vista. And btw, although the startup
repair team refuses to relable the purpose of Startup Repair, it can fix a
number of component problems in Vista besides those that don't allow you to
boot to Vista (when it works). I've used it on a number of boxes to fix
Vista when it will start up but has components that are corrupted.
Let's look at the repair options you haven't used.
Check out these options:
Usually also when someone says I tried to boot from safe mode, they haven't
tried about 10 that's spelled ten
of their options including Bootsect and BootRec.exe (instructions below):
First of all you can try Startup Repair from the DVD (you've tried this but
you have several more options) and you can try safe mode from the same
Repair link on setup from the DVD. Have you? Here are
3 options. Often system restore will work from the repair option when it
won't work from F8 or Windows Advanced Options screen in vista. You also
have access to the command prompt from Win RE or the repiar link on the DVD.
You can try the command for system restore there. It often works when other
modalities don't. I know you haven't. I'll bet you don't know what the
command is to run system restore from the command prompt from the Recovery
Environment on the Vista DVD do you?
It's %systemroot%\system32\restore\rstrui.exe and it comes from this XP
MSKB and it would be nice if MSFT supplied it on their Win RE recovery
options screen but they weren't smart enough to think of doing it.
http://support.microsoft.com/kb/304449
You can also use this command as one of the five options from the F8 Windows
Advanced Options Screen which has 5 safe modes from which to access system
restore and Last Known Good Configuration. I count 3eight options there
and I don't think you've tried but one or two of them. Often one works
when another doesn't.
If you have a Vista DVD try Startup Repair. If that doesn't work, try
SafeMode>System Restore from the Recovery Environment, and you always have
the F8 advanced options ( five of them including Last Known Good
Configuration) and a repair install (with the DVD) as well.
In addition you can use the Bootsect tool to manually repair the boot sector
by accessing the command prompt from the DVD or from F8 and typing at the
prompt:
***Startup Repair and System Restore from the Win Recovery Environment on
the DVD***
You can run Startup Repair by putting your Vista DVD in after theanguage
screen in setup. You can also run System Restore from the same
location.
You run the startup repair tool this way (and system restore from here is
also sometimes effective):
http://support.microsoft.com/kb/925810/en-us
How To Run Startup Repair In Vista Ultimate (Multiple Screenshots)
http://www.windowsvista.windowsreins...rtup/index.htm
Note The computer must be configured to start from a CD or from a DVD. For
information about how to configure the computer to start from a CD or from a
DVD, see the information that came with the computer.
2. Restart the computer. To do this, click Start, click the arrow next to
the Lock button, and then click Restart.
This usually means that you enter bios setup by whatever key or keys
(sometimes there is more than one key that will do it for your model--go to
pc manufacturer site) and configure CD to be first in the boot order (this
will allow you to boot from the Vista DVD as well):
See for ref:
Access/Enter Motherboard BIOS
http://www.michaelstevenstech.com/bios_manufacturer.htm
Boot Order in Bios (Set Boot from HD 1st)
http://www.short-media.com/images/mm...ios/bios03.jpg
Note If you cannot restart the computer by using this method, use the power
button to turn off the computer. Then, turn the computer back on.
3. Set your language preference, and then click Next.
Note In most cases, the startup repair process starts automatically, and you
do not have the option to select it in the System Recovery Options menu.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, click the operating system
that you want to repair, and then click Next.
6. In the System Recovery Options menu, click Startup Repair to start the
repair process.
7. When the repair process is complete, click Finish.
Additional References for Startup Repair With Screenshots:
How to Use Startup Repair:
***Accessing Windows RE (Repair Environment):***
1) Insert Media into PC (the DVD you burned)
2) ***You will see on the Vista logo setup screen after lang. options in the
lower left corner, a link called "System Recovery Options."***
Screenshot: System Recovery Options (Lower Left Link)
http://blogs.itecn.net/photos/liuhui...4/500x375.aspx
Screenshot: (Click first option "Startup Repair"
http://www.leedesmond.com/images/img...SysRecOpt2.bmp
3) Select your OS for repair.
4) Its been my experience that you can see some causes of the crash from
theWin RE feature:
You'll have a choice there of using:
1) Startup Repair
2) System Restore
3) Complete PC Restore
___________________
prompt:
Bootsect.exe is available from the \Boot\folder of the Windows Vista DVD and
can be run from within System Recovery or Windows XP on a dual boot.
1. Use Bootsect.exe to restore the Windows Vista MBR and the boot code that
transfers control to the Windows Boot Manager program. To do this, type the
following command at a command prompt: Drive:\boot\Bootsect.exe /NT60 All
In this command, Drive is the drive where the Windows Vista installation
media is located.
Note The boot folder for this step is on the DVD drive.
2. Use Bcdedit.exe to manually create an entry in the BCD Boot.ini file for
the earlier version of the Windows operating system. To do this, type the
following commands at a command prompt.
Note In these commands, Drive is the drive where Windows Vista is
installed. • Drive:\Windows\system32\Bcdedit /create {ntldr} –d "Description
for earlier Windows version"
Note In this command, Description for earlier Windows version can be any
text that you want. For example, Description for earlier Windows version can
be "Windows XP" or "Windows Server 2003".
• Drive:\Windows\system32\Bcdedit /set {ntldr} device partition=x:
Note In this command, x: is the drive letter for the active partition.
• Drive:\Windows\system32\Bcdedit /set {ntldr} path \ntldr
• Drive:\Windows\system32\Bcdedit /displayorder {ntldr} –addlast
3. Restart the computer.
____________________________
******Using the BootRec.exe Tool
Using the System Recovery Tool from the Repair link on the DVD after the
language choice in the lower left hand corner you can select command prompt
and you have the following options:
Bootrec.exe (You can use this tool to recover Vista even when you do not
receive the error message that is the title of the 2nd linked MSKB below):
How to use the Bootrec.exe tool in the Windows Recovery Environment to
troubleshoot and repair startup issues in Windows Vista
http://support.microsoft.com/kb/927392/en-us
Error message when you start Windows Vista: "The Windows Boot Configuration
Data file is missing required information"
http://support.microsoft.com/kb/927391/en-us
_____________________________________________________________
***Using the F8 Environment or a Repair Install from the DVD:***
See for ref:
Repair Install
http://www.microsoft.com/windowsxp/u...ps/doug92.mspx
Repair Install (Method 2):
http://support.microsoft.com/default.aspx/kb/315341
III Taking Full Advantage of the F8 Options (Windows Advanced Options Menu)
by startin gth ePC and tapping F8 once per second:
You could also:
Think: I have 4 different ways to get back my XP at F8 and try 'em in order.
1) Safe Mode 2) Safe Mode with Cmd to Sys Restore which is simply a cmd
prompt in safe mode 3) Safe Mode with Neworking 4) LKG or Last Known Good
Configuration
Try to F8 to the Windows Adv Options Menu>try 3 safe modes there (I don't
use WGA) and Last Known Good>then I go to Win RE in Vista. That gives you a
choice of Safe Mode, Safe Mode with Networking,and Safe Mode with Command
Prompt.
These methods are outlined in
A description of the Safe Mode Boot options in Windows XP/and Vista
http://support.microsoft.com/kb/315222/
How to Use System Restore
http://bertk.mvps.org/
Frequently Asked Questions Regarding System Restore from MSFT:
http://www.microsoft.com/technet/pro.../faqsrwxp.mspx
Using System Restore
http://tinyurl.com/dvekb
System Restore for Windows XP
http://www.kellys-korner-xp.com/xp_restore.htm
How to start the System Restore tool at a command prompt in Windows XP
http://support.microsoft.com/default...b;en-us;304449
Repair Install: (This option has the best chance of succeeding and it
preserves everything in your OS--you do not lose anything with this option):
Make sure the DVD you have is a Vista DVD
Pitfalls: If the DVD came from friend or relative or P2P, you may have
problems. P2P besides being illlegal in many countries including the U.S.
can be corrupt. If CD came from friend or relative, they may have given
you the CD to use but if product key is in use, MSFT is not going to accept
it for activation. Make sure you clean the CD carefully using proper
cleaning fluid and strokes that radiate from center like spokes on a wheel.
Again a repair install has the most likely chance to succeed in XP, (and can
work in Vista) but you need
to have a Vista DVD.
First, in order to do a Repair Install You must boot to the bios setup and
position booting from the "CD" first in the boot order--it probably will not
say DVD but might.
Booting to Bios Setup:
For 85% of PC's and all Dells you can tap the F2 key to reach bios setup.
How To Enable DVD/CD Rom Support (put CD boot first) in bios setup boot
order:
http://xphelpandsupport.mvps.org/how..._support_i.htm
Screen Shot of bios setup boot order:
http://www.poy.net/proxy/bios2.jpg
Repair Install Does Not Lose Anything; you may need to try 2-3 times but
that's rare.
How To Repair Install
http://support.microsoft.com/kb/3153...22120121120120
Screen Shot Repair Install
http://www.windowsreinstall.com/winx...exfullpage.htm
Good luck,
CH
"Brendan" <bunkoman@iolfree.ie> wrote in message
news:OsXnyixyHHA.312@TK2MSFTNGP04.phx.gbl...
> in the bind. The entire system is now a bit wobbly. I have tried 'start
> repair' from the disc- answer 'no probs' What are my options now?
>> a
>> on SR
>> all the time.
>>> I
>>> comments or
07-23-2007   #6
Brendan
Thanks Mick: I share your opinions on SR to a large extent, The only thing
is that I did use it and now my system is kinda wobbly. I always thought of
a clean install as a last desperate resort. Obviously tho' it has its
advantages. At what stage would you go for clean install?
> SR
> all the time.
>> I
>> or
RB
Similar Threads for: System Repair-Vista Ultimate
Can I repair Vista Premium with upgrade to Ultimate? Vista installation & setup
System repair removed my Ultimate Extras. Vista General
vista repair for old system Vista performance & maintenance
Repair ASP.NET - Vista Ultimate Vista General
Repair or reinstall Vista Ultimate? Vista installation & setup
