| | Wi Fi problems with Vista Home Premium + Acer Aspire 9304 Hello everybody, I'm experiencing an annoying problem with Vista and Wi-Fi connection. It seems that Vista, although seeing the wi-fi signal, can't connect to the Home LAN (which is fully open). Firewall disabled, any suggestions? This is the actual configuration of the LAN and Notebook: DHCP disable (from control pannel disabled also in regedit (the value DhcpConnForceBroadcastFlat and activated the value DhcpConnDisableBcastFlagToggle) TCP/ip (IPv4) IP: 192.168.0.10 SUB Mask: 255.255.255.0 Gateway: 192.168.0.1 (IP Router) Dns: 192.168.0.1 -------------------- Router NET GEAR DG834: TCP/IP Lan: 192.168.0.1 (IP for access the router) Subnet Mask Ip: 255.255.255.0 Server DHCP: enabled IP starting: 192.168.0.2 final: 192.168.0.254 ---------------------- Access Point D-LINK DWL-G700AP: DHCP disabled Beginnin: 192.168.0.100 Final: 192.168.0.200 IP static: 192.168.0.50 Subnet mask: 255.255.255.0 Gateway: 192.168.0.1 DNS Server: 192.168.0.1 ---------------------- IPCONFIG /all Microsoft Windows [Versione 6.0.6000] Copyright (c) 2006 Microsoft Corporation. Tutti i diritti riservati. C:\Users\Erminio>ipconfig /all Configurazione IP di Windows Nome host . . . . . . . . . . . . . . : PC-Erminio Suffisso DNS primario . . . . . . . . : Tipo nodo . . . . . . . . . . . . . . : Ibrido Routing IP abilitato. . . . . . . . . : No Proxy WINS abilitato . . . . . . . . : No Scheda LAN wireless Connessione rete wireless: Stato supporto. . . . . . . . . . . . : Supporto disconnesso Suffisso DNS specifico per connessione: Descrizione . . . . . . . . . . . . . : Atheros AR5005G Wireless Network Adap ter Indirizzo fisico. . . . . . . . . . . : 00-19-7E-56-55-67 DHCP abilitato. . . . . . . . . . . . : No Configurazione automatica abilitata : Sì Scheda Ethernet Connessione alla rete locale (LAN): Stato supporto. . . . . . . . . . . . : Supporto disconnesso Suffisso DNS specifico per connessione: Descrizione . . . . . . . . . . . . . : Controller di rete NVIDIA nForce Indirizzo fisico. . . . . . . . . . . : 00-16-D3-56-42-44 DHCP abilitato. . . . . . . . . . . . : Sì Configurazione automatica abilitata : Sì Scheda Tunnel Connessione alla rete locale (LAN)*: Stato supporto. . . . . . . . . . . . : Supporto disconnesso Suffisso DNS specifico per connessione: Descrizione . . . . . . . . . . . . . : isatap.{572C7C07-6E73-4A30-B6C0-DD439 D500F62} Indirizzo fisico. . . . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP abilitato. . . . . . . . . . . . : No Configurazione automatica abilitata : Sì Scheda Tunnel Connessione alla rete locale (LAN)* 2: Stato supporto. . . . . . . . . . . . : Supporto disconnesso Suffisso DNS specifico per connessione: Descrizione . . . . . . . . . . . . . : isatap.{A14FFF44-60BE-444F-85A9-7B01C F5044D6} Indirizzo fisico. . . . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP abilitato. . . . . . . . . . . . : No Configurazione automatica abilitata : Sì Thank you everubody for your help! |
| | RE: Wi Fi problems with Vista Home Premium + Acer Aspire 9304 Correct me if I am wrong, but I thought that the Wireless Router from NET GEAR is a DG834G whereas you have a DG834 "Ermanno" wrote: > Hello everybody, I'm experiencing an annoying problem with Vista and Wi-Fi > connection. It seems that Vista, although seeing the wi-fi signal, can't > connect to the Home LAN (which is fully open). Firewall disabled, any > suggestions? > This is the actual configuration of the LAN and Notebook: > > DHCP > disable (from control pannel > disabled also in regedit (the value DhcpConnForceBroadcastFlat and activated > the value DhcpConnDisableBcastFlagToggle) > > TCP/ip (IPv4) > IP: 192.168.0.10 > SUB Mask: 255.255.255.0 > Gateway: 192.168.0.1 (IP Router) > Dns: 192.168.0.1 > > -------------------- > > Router NET GEAR DG834: > TCP/IP Lan: 192.168.0.1 (IP for access the router) > Subnet Mask Ip: 255.255.255.0 > > Server DHCP: enabled > IP starting: 192.168.0.2 > final: 192.168.0.254 > > ---------------------- > > Access Point D-LINK DWL-G700AP: > DHCP disabled > Beginnin: 192.168.0.100 > Final: 192.168.0.200 > > IP static: 192.168.0.50 > Subnet mask: 255.255.255.0 > Gateway: 192.168.0.1 > DNS Server: 192.168.0.1 > > ---------------------- > IPCONFIG /all > > Microsoft Windows [Versione 6.0.6000] > Copyright (c) 2006 Microsoft Corporation. Tutti i diritti riservati. > > C:\Users\Erminio>ipconfig /all > > Configurazione IP di Windows > > Nome host . . . . . . . . . . . . . . : PC-Erminio > Suffisso DNS primario . . . . . . . . : > Tipo nodo . . . . . . . . . . . . . . : Ibrido > Routing IP abilitato. . . . . . . . . : No > Proxy WINS abilitato . . . . . . . . : No > > Scheda LAN wireless Connessione rete wireless: > > Stato supporto. . . . . . . . . . . . : Supporto disconnesso > Suffisso DNS specifico per connessione: > Descrizione . . . . . . . . . . . . . : Atheros AR5005G Wireless Network Adap > ter > Indirizzo fisico. . . . . . . . . . . : 00-19-7E-56-55-67 > DHCP abilitato. . . . . . . . . . . . : No > Configurazione automatica abilitata : Sì > > Scheda Ethernet Connessione alla rete locale (LAN): > > Stato supporto. . . . . . . . . . . . : Supporto disconnesso > Suffisso DNS specifico per connessione: > Descrizione . . . . . . . . . . . . . : Controller di rete NVIDIA nForce > Indirizzo fisico. . . . . . . . . . . : 00-16-D3-56-42-44 > DHCP abilitato. . . . . . . . . . . . : Sì > Configurazione automatica abilitata : Sì > > Scheda Tunnel Connessione alla rete locale (LAN)*: > > Stato supporto. . . . . . . . . . . . : Supporto disconnesso > Suffisso DNS specifico per connessione: > Descrizione . . . . . . . . . . . . . : isatap.{572C7C07-6E73-4A30-B6C0-DD439 > D500F62} > Indirizzo fisico. . . . . . . . . . . : 00-00-00-00-00-00-00-E0 > DHCP abilitato. . . . . . . . . . . . : No > Configurazione automatica abilitata : Sì > > Scheda Tunnel Connessione alla rete locale (LAN)* 2: > > Stato supporto. . . . . . . . . . . . : Supporto disconnesso > Suffisso DNS specifico per connessione: > Descrizione . . . . . . . . . . . . . : isatap.{A14FFF44-60BE-444F-85A9-7B01C > F5044D6} > Indirizzo fisico. . . . . . . . . . . : 00-00-00-00-00-00-00-E0 > DHCP abilitato. . . . . . . . . . . . : No > Configurazione automatica abilitata : Sì > > Thank you everubody for your help! |
| Sleep Problems with Acer Aspire 4530-6823 | General Discussion | |||
| nvidia vga driver problems acer aspire 5520 | Drivers | |||
| acer orbicam on acer aspire 5600 notebook | Vista hardware & devices | |||
| Acer Aspire 5050 sound problems | Vista hardware & devices | |||
| Vista on Acer Aspire | Vista General | |||
