Vista Tutorial - Acrobat reader problem
Old 07-23-2007   #1 (permalink)
mkbj
Guest
When I try to open a link that requires acrobat reader I get a message
stating there is an internal error. I click ok and it procedes like it is
going to open the document, then I get another message: There was an error
opening this document. This viewer cannot decrypt this document.
Then of course, the document is blank.
Other times I get an error..(can't remember it right now) that says
something about the font....it then only displays part of the document.
Am I doing something wrong? Thanks for your help.
Old 07-23-2007   #2 (permalink)
Mike Hall - MVP
Guest
Re: Acrobat reader problem
Uninstall Adobe Reader and then do a search on Foxit, which you then
download..
"mkbj" <mkbj@discussions.microsoft.com> wrote in message
newsBB49C5F-2404-443E-9499-AC938747162B@microsoft.com...
Mike Hall
MS MVP Windows Shell/User
http://msmvps.com/blogs/mikehall/
Old 07-23-2007   #3 (permalink)
Charles W Davis
Guest
http://www.foxitsoftware.com At 3.9 MB, you will never go back to the 16.9
MB Adobe Reader.
"Mike Hall - MVP" <mikehall@mvps.org> wrote in message
news:%23dos64YzHHA.536@TK2MSFTNGP06.phx.gbl...
> download..
>> is
>> error
> Mike Hall
Old 07-24-2007   #4 (permalink)
Steve
Guest
>MB Adobe Reader.
Until you discover that many docs won't print on Foxit...
When they discover the center of the universe,
a lot of people will be disappointed to discover they are not it.
....Bernard Bailey
Old 08-04-2007   #5 (permalink)
Ian Betts
Guest
Delete your Adobe Reader in the normal way and go back to Adobe.com and
download again and install. This will save you agonizing over a problem.
Most times these downloads work , sometimes they just don't. As the program
is free, nothing lost in starting over.
Ian
Acrobat Reader v9.1 Software
Acrobat Reader 9 and Printing from IE9 B2 Vista General
problem with Adobe acrobat 7 plus adobe reader 8.12 Vista General
Acrobat Reader 7 problems Vista General
Adobe Acrobat Reader 8 Vista General
