Vista - Fax and Scan, problem reading old Faxes from XP Fax
Old 07-24-2007   #1 (permalink)
chunnel
I just sent my first fax from Vista Fax and Scan. Then, after I created a
Parent Folder called Fax in Documents and after Fax and Scan created the sent
folder, I dropped in all 2,000 plus faxes into that same folder. I know that
I have the right folder because the first sent fax is there. However, I want
to be able to see these older faxes from XP in the Sent Folder in Fax and
Scan, but it is only seeing the first one. In XP, this was simple, I would
drop in the older faxes into the default send folder and as soon as I started
up Fax again, all the older faxes would show up with Subject, To, Created
date, Pages, etc... And this was all searchable.
new problem receiving faxes get error message Vista print fax & scan
hardware problem only reading 24g out of 120 does anyone know what to do General Discussion
How can I view previous Sent Faxes in Fax and Scan? Vista print fax & scan
Fax and Scan will not recognize faxes in the Sent Folder Vista print fax & scan
Vista Fax and Scan doesn't see old faxes from XP Fax in Outbox Vista print fax & scan
