Vista - 2nd monitor is hdtv
Old 07-26-2007   #1 (permalink)
Swtjmpsht
2nd monitor is hdtv
I wanted to see my movies and stuff in my computer to my tv but I am not able
to see it. No signal is going to the tv. Display settings do show that both
monitors are there. Where do I go solve this problem?
sj
Old 07-26-2007   #2 (permalink)
Gladiator
Re: 2nd monitor is hdtv
On Thu, 26 Jul 2007 00:38:00 -0700, Swtjmpsht
>sj
What's your video card? I am doing the same but to an HDTV projector
instead. I have no issue using a Nvidia video card and latest drivers.
I just set second monitor in display properties to clone mode. Have
you done that?
Monitor + HDTV WMP 11 & VLC problems Graphic cards
RGB to S-video converter for using HDTV as computer monitor? Vista General
HDTV or LCD Monitor? General Discussion
Using HDTV as monitor - no sound Vista General
My 2nd monitor(hdtv) no sound Vista General
