| | Changed Power Options now computer will not wake up. I wanted to make the Shut down in Vista the same as XP and went to Power Options,then Power Buttons and Lid, then Start Menu Power Button, then Sleep and in drop down clicked Shut Down then OK. The Start Button changed and when it was clicked the computer shut down. When I went to re-start the computer it is just blank. Nothing is happening, even the mouse and keyboard do nothing - dont even light up. |
Power outage during computer wake-up stops 32-bit processes from running | General Discussion | |||
| Power Options - Disable Prompt for password when computer resumesfrom standby | PowerShell | |||
| Power Options cannot be changed via Remote Desktop | Vista General | |||
