Vista - Problem with BITS on Vista
Old 07-26-2007   #1 (permalink)
skizi
I've been having problems with my Background Intelligent Transfer Service
(BITS) for a while now. I don't really know how I would re-download or update
it since I can't seem to find the download on microsoft.com (all they have is
the xp versions).
When I head into my service list the BITS file shows up with an error next
to it. It reads:
<Failed to Read Description. Error Code:988>
And when I head into properties I get these errors:
-Configuration Manager: A general internal error occured.
-Invalid access to memory location.
Can anyone here give advice to what I can do?
BITS Problem Vista General
Installation Problem EPSON TM-U220D on WIndows VISTA (32 Bits) Vista print fax & scan
BITS service problem General Discussion
Vista 32 bits to Vista 64 bits without loosing apps. Vista installation & setup
Internet Explorer 7 (32-bits) keeps on freezing wile the 64-bits works OK in Vista 64 Vista General
