Will not wake up ...
  1. #1
    Michael Tissington Guest
    I have a number of scheduled tasks
    1) To download virus definitions
    2) Windows Updates
    3) Symantec backup ..
    If my computer is in a deep sleep (not sure about a light sleep) then it
    will not wake up and run.
    How can I auto wake from a deep sleep to run the tasks ?
  2. #2
    Marco Desloovere Guest
    Re: Will not wake up ...
    >2) Windows Updates
    Did you enable the task option that wakes the computer to execute the
    task?
    Marco
  3. #3
    guy Guest
    Buried in the Windows Task Scheduler is a properties box to WAKE the
    computer. If your tasks cannot do that on their own, you can start them off
    (or just a dummy task) by waking with the Scheduler. I believe this works
    down to S3 sleep states but will check my info and get back if that was
    wrong.
    "Marco Desloovere" <marco_desloovere@yahoo.com> wrote in message
    news:ufupa3daldcdihfs0a9h82e0ia5gc71ieu@4ax.com...
    >>2) Windows Updates
    > task?
    > Marco
  4. #4
    AEG and Symantec Backup do not use the task scheduler
    How do I create a dummy task, all the options seem to want to run a
    program...
Will not wake up ... problems?
wake on lan Bill PowerShell 0 05 Mar 2009
Wake on lan Bill PowerShell 0 05 Mar 2009
Wake me up amitsa General Discussion 2 29 Dec 2008
Wake on Lan Stuart Vista General 0 20 Nov 2007
Wake up on its own Larry@avstim.com Vista General 10 09 Apr 2007
