Vista - Keyboard volume controls don't work
Old 07-29-2007   #1 (permalink)
Bobby
I recently purchased a Logitech keyboard (the Easycall (Skype) model). It
works well apart from one thing.
The volume up/down controls don't adjust the main system (speaker) volume
levels. Instead they appear to adjust the "Logitech Setpoint Event Manager
(UNICODE)" levels - whatever the Hell that is.
How can I get these hardware controls to work?
Cheers.
Bobby
Old 07-29-2007   #2 (permalink)
Ian Betts
Re: Keyboard volume controls don't work
Ian
"Bobby" <bobby@europe.com> wrote in message
news:OK$uFmc0HHA.3788@TK2MSFTNGP02.phx.gbl...
> Cheers.
> Bobby
I think you need to go Control/Panel/Sounds and look what hardware is
installed. While in CP look at the Logitec icon to set up.
Old 07-29-2007   #3 (permalink)
Cal Bear '66
Have you looked in Control Panel > Keyboard for any keyboard setup options?
I Bleed Blue and Gold
GO BEARS!
>I recently purchased a Logitech keyboard (the Easycall (Skype) model). It works
> Cheers.
> Bobby
Old 07-29-2007   #4 (permalink)
Richard Urban
Start by contacting Logitech. It is their software that must interface with
the operating system.
Regards,
Richard Urban
> Cheers.
> Bobby
Old 07-29-2007   #5 (permalink)
Revolt
> Cheers.
> Bobby
If you didn't install the setpoint software then it would probably work
fine. I have a Creative Multimedia keyboard and every keyboard function
works perfectly in Vista without installing the Creative drivers. It has
buttons for Word and Excel but I don't have either of those apps installed
so don't know if they work or not.
Old 07-30-2007   #6 (permalink)
Bobby
Thanks for all of the suggestions.
I found a cure (on a Logitech forum). Make the file (setpoint.exe) run in XP
compatibility mode - and all of the keys are perfect!
Bobby
> Cheers.
> Bobby
windows explorer not responding when using volume controls, HELP! Drivers
Volume controls returning to zero (XP0 Live Messenger
Volume control doesn't work / MS Natural MM Keyboard Vista hardware & devices
Sound Volume Controls Vista General
Wave Volume controls Vista General
