purchased a new laptop. it came with vista basic. purchased an
upgrade license and now have vista home premium. this was done 3.5
months ago. began having problems with windows media center. would
not play a dvd, said no codec was installed. then i found out that
windows media player will not even launch. attempted to put the
upgrade disk in and reinstall vista the way you used to do in xp (as
an upgrade) on first reboot it says cannot write the XXX? that is
required to finish the install and quits. had done this 5 times. is
there a way to reinstall media player and windows media center
without doing an entire install. another problem is my Zune software
will not make a short movie as it also says the audio codec is not
installed. just got media player 9 codec taht is required and
installed it. it still says the audio codec is not installed. vista
refuses to play wmv files which is the windows media player format.
thanks LaMar
Posted with NewsLeecher v3.9 Beta 6
Web @ http://www.newsleecher.com/?usenet
