Vista - Create Dated Folder with a right click of the mouse
Old 08-01-2007   #1 (permalink)
Eliot Powell
Hello,
When I download my photos onto the PC I like to put them in dated folder.
E.g. for today, 31-July-2007 I name the folder in the format
YY-MM-DD so that I can order the folders by date.
07-07-31
I would like to be able to right click and create a folder named as above,
can anyone point me in the right direction?
Thanks a lot!
(Was posted in xp group but I need to be able to do this in Vista as well,
and Vista seems different)
Old 08-01-2007   #2 (permalink)
Jane C
Re: Create Dated Folder with a right click of the mouse
Hello Eliot,
Navigate to where you want the folder then right-click and select New >
Folder. Rename it 07-07-31.
In Vista, there is already a Pictures folder under your username, ie
C:\Users\yourname\Pictures. You can create new folders there for your
photos.
Jane, not plain 64 bit enabled :-)
Batteries not included. Braincell on vacation ;-)
MVP Windows Shell/User
"Eliot Powell" <ebp@hotmail.com> wrote in message
news:C21EFBBA-53A2-4CE5-BCBF-160964BA4A37@microsoft.com...
> Hello,
> 07-07-31
> Thanks a lot!
Old 08-01-2007   #3 (permalink)
E Powell
OK there is that way, but it is slow and and an operation I need to do a
lot, which means an error may slip in.
I would like to be able to right click and then in addition to the "new ->
folder" option I have "new -> "dated folder". This involves customising
windows somehow and I am not sure where to start to look.
"Jane C" <janecolman@invalid.iinet.net.au> wrote in message
newsDB02159-97E5-4539-BF18-83E6F6112A75@microsoft.com...
> Hello Eliot,
> photos.
>> Hello,
>> 07-07-31
>> above,
>> Thanks a lot!
>> well, and Vista seems different)
Unable to create a new text doc using right click Vista General
Can't create shortcuts via Right-Click General Discussion
How do I change the mouse click to just one click Vista General
Right-click no option to create "folder" Vista file management
hot to change mouse to single click instead of double click to ope Vista hardware & devices
