| | #11 (permalink) |
| | Re: Battery Meter on task bar does not show Hi all, I recently experienced the same exact problem: both volume and battery meter disappeared from task bar and were grayed out in the notification area. After one automatic update my volume option became active again, and after Service Pack 1 installation, my Power option was active again. Hopefully, nothing else will mysteriously disappear! Hope this helps! -- kdurig06 ------------------------------------------------------------------------ kdurig06's Profile: http://forums.techarena.in/member.php?u=52755 View this thread: http://forums.techarena.in/showthread.php?t=793508 http://forums.techarena.in |
| | #12 (permalink) |
| | Re: Battery Meter on task bar does not show Note in response to my previous reply: upon installing additional updates after SP1, my volume and network icons disappeared again! and they were greyed out in the notification area! However, after reading on another forum, I learned that all I needed to do was to restart my computer, and it worked! They reappeared and all 4 notification areas in the taskbar properties are again active... for now at least...I'm keeping my fingers crossed... -- kdurig06 ------------------------------------------------------------------------ kdurig06's Profile: http://forums.techarena.in/member.php?u=52755 View this thread: http://forums.techarena.in/showthread.php?t=793508 http://forums.techarena.in |
| | #13 (permalink) |
| | Re: Battery Meter on task bar does not show I didnt read through all of the posts but i had a similar issue, I lost my battery and network icons from my system tray after installation of Vista service pack 1 on my HP Pavillion dv2718 laptop and restarts did not help at all. I also had the options to turn them on greyed out in the toolbar properties. In addition, my computer would not re-initiate after it went into sleep mode and would crash and have to be hard reset anytime it went into sleep. I did not feel comfortable messing with the regedit. After many hours with vista tech support, a senior tech called me back the next day and had me update my BIOS from the HP website specific to my machine. There was a more current version available so we downloaded that. After that, it was all back to good. Thought you all may want to know. - try this first! -- korysamson@xxxxxx ------------------------------------------------------------------------ korysamson@xxxxxx's Profile: http://forums.techarena.in/members/k...-gmail-com.htm View this thread: http://forums.techarena.in/vista-help/793508.htm http://forums.techarena.in |
| | #14 (permalink) |
| | Re: Battery Meter on task bar does not show http://windowshelp.microsoft.com/Win...72c8e1033.mspx I think this might help .. I had the same prob .. but it appeared to be so simple <at least for me> so i thought i could post the solutionhere.. try to read : How can I hide the battery icon in the notification area? posted in the above link .. and just reverse the operation.. hope that helps.. Regards reficuL -- reficuL ------------------------------------------------------------------------ reficuL's Profile: http://forums.techarena.in/members/91263.htm View this thread: http://forums.techarena.in/vista-help/793508.htm http://forums.techarena.in |
| | #15 (permalink) |
| | Re: Battery Meter on task bar does not show I have the same issue for an XPS 1530. It's definitely an issue with Vista and it also happened after I installed 'updates'. I have tried shutting down once but this did not bring the icons back. Any clues? The last post is not helpful as all three boxes (Power, Network and Volume) are greyed and cannot be selected. -- waldorf ------------------------------------------------------------------------ waldorf's Profile: http://forums.techarena.in/members/151442.htm View this thread: http://forums.techarena.in/vista-help/793508.htm http://forums.techarena.in |
| Battery meter | General Discussion | |||
| Battery meter | Vista General | |||
| Battery Meter | Vista hardware & devices | |||
| Battery Meter does not show time remaining. | Vista General | |||
