Vista - Battery Meter on task bar does not show
Old 08-01-2007   #1 (permalink)
Bob from down under
Hi all, hope you can assist, my battery meter does not show and when I go to
the task bar notification area to check it is on, the check box is grayed
out as is the volume box,.... any ideas to remedy?
Old 08-01-2007   #2 (permalink)
Bob J
RE: Battery Meter on task bar does not show
Are you running on mains power, I ask because my battery meter only appears
when running on battery.
Acer Aspire
Regards
Bob J
If advise given from anyone, solves problem or not, or if solved from
another source,post back & let us know.
Then we all benefit.
Old 08-01-2007   #3 (permalink)
Bob from down under
Re: Battery Meter on task bar does not show
Mains or battery does not show, laptop is a Toshiba. I went back to the
store and all the display laptops show when in mains power is connected.
"Bob J" <BobJ@discussions.microsoft.com> wrote in message
news26A8D76-F97F-4EE4-A838-B3AB566BAEF6@microsoft.com...
> appears
> Acer Aspire
> Regards
> Bob J
>> to
Old 08-02-2007   #4 (permalink)
Ian Betts
"Bob from down under" <bobnospam@justmail.biz> wrote in message
news:uWxb2YB1HHA.5736@TK2MSFTNGP04.phx.gbl...
>> appears
>> Acer Aspire
>> Regards
>> Bob J
>>> go to
>>> grayed
Normally the battery shows and has a cable and plug icon when mains power is
on. You may need to full charge the battery before this will happen on first
use.
To find the tick box for this icon right click the taskbar, chose
Properties, Notification Area tab. Under System Icons select Power.
If this is not there your battery is not installed ob you laptop.
Ian
Old 08-27-2007   #5 (permalink)
Lakshmi
Even i am facing the same problem i have a Sony VAIO and not able to get the
battery meter on my taskbar as well as the Volume it is greyed out in the
Notification area
"Ian Betts" wrote:
Quote:
> "Bob from down under" <bobnospam@xxxxxx> wrote in message
> news:uWxb2YB1HHA.5736@xxxxxx
> > "Bob J" <BobJ@xxxxxx> wrote in message
> > news26A8D76-F97F-4EE4-A838-B3AB566BAEF6@xxxxxx
> >> appears
> >> Acer Aspire
> >> Regards
> >> Bob J
> >>> go to
> >>> grayed
> use.
> Ian
Old 08-28-2007   #6 (permalink)
Lakshmi
Can anyone please Help as per my last request?
> >> appears
> >> Acer Aspire
> >> Regards
> >> Bob J
> >>> go to
> >>> grayed
> use.
> Ian
Old 09-16-2007   #7 (permalink)
WishForNewOS
Same problem here with HP Pavilion. The batter/power meter always showed -
whether in plug-in or battery mode - ALWAYS. Plus I always had the option to
change this via notification icons in task bar properties.
However, ever since I did a Windows update yesterday, the darn icon is gone
and I have no way to pic this option because the box is grayed out
(non-accessible) in the notification properties screen.
Am sooooo annoyed with this problem as I swtich between AC and battery power
a lot and use the icon to change my power scheme frequently. It's MY
COMPUTER not MICROSOFTS and I AM TIRED OF BEING AT THEIR MERCY.
I WANT MY POWER ICON BACK......WILL BILL GATES PLEASE HELP !
Txs.
Truly frustrated.
Old 09-24-2007   #8 (permalink)
tragicmuffin
This seems to be some bug in Vista, it happened to me too.
I found a fix on some other forum, and it worked for me.
1. First you need to open the Windows "Run" dialog, which you can find
either in the "Accessories" folder in the "Start" menu, or by pressing
"Windows Key + R"
2. Next type in "regedit" which will bring up the Registry Editor.
3. Now go to "Edit" and "Find..." (or Ctrl + F) and search for
"iconstreams".
4. When the results come up, delete the keys "IconStreams" and
"PastIconStreams".
5. Restart the computer, and recheck the missing icons in the taskbar
properties.
This works, but only temporarily it seems. My icons disappeared again,
and I found the keys had come back, but getting rid of them fixed it
again.
tragicmuffin
tragicmuffin's Profile: http://forums.techarena.in/member.php?userid=31670
View this thread: http://forums.techarena.in/showthread.php?t=793508
Old 09-24-2007   #9 (permalink)
jonathan perreault
actually this happen to me too but all i need to do was reboot and i get it
back, some have said if you log off and relog you also get it back
Jonathan Perreault
Personnal Advice To You:
#1: Do Not Undermine Windows's Work, Or It'll Undermine You As A User.
#2: Torture Windows (Any) Now Before It Tortures You
Best Comments From Users:
No Matter The Problem Even With Linux, It's Microsoft's And Windows's Faults
A common mistake that people make when trying to design something completely
foolproof is to underestimate the ingenuity of complete fools.
"tragicmuffin" <tragicmuffin.2xg4zf@xxxxxx> wrote in message
news:tragicmuffin.2xg4zf@xxxxxx
> "Windows Key + R"
> "iconstreams".
> "PastIconStreams".
> properties.
> again.
> tragicmuffin
Old 09-27-2007   #10 (permalink)
Translator English - French - Creole
they were right just log off and relog and you'll get it back
Jonathan Perreault
"jonathan perreault" <jonperreault@xxxxxx> wrote in message
news:F19DD34A-01F3-4D79-B4A0-257431D5FAF2@xxxxxx
> it back, some have said if you log off and relog you also get it back
> Jonathan Perreault
> Faults
> completely foolproof is to underestimate the ingenuity of complete fools.
>> "Windows Key + R"
>> "iconstreams".
>> "PastIconStreams".
>> properties.
>> again.
>> tragicmuffin
Battery meter General Discussion
Battery meter Vista General
Battery Meter Vista hardware & devices
Battery Meter does not show time remaining. Vista General
