| | Media Player 11 problem I am running Vista. Media Player was working. Now when I double click on it nothing happens. I can start the Player if I log on as another user. |
| | RE: Media Player 11 problem How can I fix this? "Fredh117" wrote: > I am running Vista. Media Player was working. Now when I double click on it > nothing happens. I can start the Player if I log on as another user. |
| | Re: Media Player 11 problem Right click on the Taskbar, select Task Manager, Processes tab, select wmplayer.exe and press End Process button. -- I Bleed Blue and Gold GO BEARS! "Fredh117" <Fredh117@discussions.microsoft.com> wrote in message news:377D72CD-DFFA-4DEC-BBFF-57D0BFAB4B67@microsoft.com... >I am running Vista. Media Player was working. Now when I double click on it > nothing happens. I can start the Player if I log on as another user. |
| | Re: Media Player 11 problem On Aug 2, 12:02 pm, Fredh117 <Fredh...@discussions.microsoft.com> wrote: > I am running Vista. Media Player was working. Now when I double click on it > nothing happens. I can start the Player if I log on as another user. Sounds like an issue with your user account's temporary application data given the situation you've described. 1. Click on the start menu. 2. Look for the box that says in Italic 'Start Search'. 3. Click on the start search box and type '%appdata%' (without the quotes) 4. Press enter on your keyboard. 5. Go to the parent directory (Go up one level) or however you want to phrase this. 6. Find the directory 'Local' and open it 7. Find the directory 'Microsoft' and open it 8. Look for the directory 'Windows Media Player'. 9. Delete it. 10. There, your done. Your temporary applicata data for Windows Media Player si gone. ****WARNING**** This resets most your Windows Media Player settings to default and you'll lose your library index. Windows will ahve to slowly re-add your mp3s and slowly redownload the pictures for those albums) There is also a registry key that contains information about this too: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MediaPlayer You might want to delete that key through Registry Editor if removing the temporary application data doesn't work. |
| Media player problem | General Discussion | |||
| Problem with Media Player | Vista music pictures video | |||
| Media Player problem!!!! | Vista music pictures video | |||
| IE7 media links & Media Player problem | Vista General | |||
| Media player problem | Vista music pictures video | |||
