Vista Tutorial - Medai Player 11 won't monitor folders
Old 08-02-2007   #1 (permalink)
Chuck
Guest
How do I fix this. It will not play on of the music as it says that my file
is missing or lost.
Old 08-03-2007   #2 (permalink)
Dale
Guest
RE: Medai Player 11 won't monitor folders
If WMP says that the files are missing, they usually are. Did you delete
them? If you're sure the files are still there, try pressing F3 and checking
the box to add files previously deleted.
If you still have problems, try rebuilding your database following the
instructions at http://zachd.com/pss/pss.html#medialibrary.
Dale
Dale Preston
MCAD C#
MCSE, MCDBA
> file
> is missing or lost.
CP problem with media player with generic monitor Vista music pictures video
Media Player 11 has made all folders on system act like music cont Vista music pictures video
windows media player hang and the monitor goes off on Vista OS Vista General
Windows Media Player 11 is not adding media in the monitored folders Vista General
Monitor Folders Issue Vista music pictures video
