| | 32bit vs 64bit Hi Just getting ready to setup my new Vista machine, but I'm a bit uncertain about if I'm going for 32bit or 64bit. I actually have access to both versions. I've heard that there are issues with 64 bit, such as antivirus, games and so on. Are there actually any real benefits for 64bit at the moment, besides support for more memory. I'm very happy for arguments for both options. /A. |
| | Re: 32bit vs 64bit "Andy" <andy@blocker.com> wrote in message news:74E40EA9-1522-4EC0-9C23-039D528D89F3@microsoft.com... > Hi > > Just getting ready to setup my new Vista machine, but I'm a bit uncertain > about if I'm going for 32bit or 64bit. I actually have access to both > versions. I've heard that there are issues with 64 bit, such as antivirus, > games and so on. Are there actually any real benefits for 64bit at the > moment, besides support for more memory. > I'm very happy for arguments for both options. > > /A. > > > Pay your money and take your choice. You need 64bit motherboard, processor and 2gb Ram to make the 64 worth while of course. -- Ian |
| | Re: 32bit vs 64bit Yes, there are issues. What you have heard is correct. Unless you have to run mission critical 64bit apps requiring greater than 4gb, you are best to stay with the 32bit OS.. "Andy" <andy@blocker.com> wrote in message news:74E40EA9-1522-4EC0-9C23-039D528D89F3@microsoft.com... > Hi > > Just getting ready to setup my new Vista machine, but I'm a bit uncertain > about if I'm going for 32bit or 64bit. I actually have access to both > versions. I've heard that there are issues with 64 bit, such as antivirus, > games and so on. Are there actually any real benefits for 64bit at the > moment, besides support for more memory. > I'm very happy for arguments for both options. > > /A. > > -- Mike Hall MS MVP Windows Shell/User http://msmvps.com/blogs/mikehall/ |
| | Re: 32bit vs 64bit On Fri, 3 Aug 2007 15:47:56 +0200, "Andy" <andy@blocker.com> wrote: >Hi > >Just getting ready to setup my new Vista machine, but I'm a bit uncertain >about if I'm going for 32bit or 64bit. I actually have access to both >versions. I've heard that there are issues with 64 bit, such as antivirus, >games and so on. Are there actually any real benefits for 64bit at the >moment, besides support for more memory. >I'm very happy for arguments for both options. > >/A. > The only advantage to using 64 bit at THIS TIME is if you have both the hardware and it's drivers plus software that actually take advantage of it. For most people that isn't a reality...yet. A pretty good analogy would be if you could, buying a hydrogen car now. Likely it would stay in your garage since there are few places to buy hydrogen fuel. A good idea and the future, but too early. Ditto for 64 bit. |
| | Re: 32bit vs 64bit "Mike Hall - MVP" <mikehall@mvps.org> wrote in message news:e2STpcd1HHA.5980@TK2MSFTNGP04.phx.gbl... > Yes, there are issues. What you have heard is correct. Unless you have to > run mission critical 64bit apps requiring greater than 4gb, you are best > to stay with the 32bit OS.. I'm running Vista64 and AVG antivirus works fine and so do the games I have installed so far. I have 4gb of ram and want the OS to have full access to it. |
| | #6 (permalink) |
| | Re: 32bit vs 64bit Noddy This is part of a new finding.. I would give the rest, but the server on which the information resides appears to be down temporarily.. "Anti virus software for the 64-bit version of Windows Vista is struggling to properly protect the operating system, according to a new test by the Virus Bulletin security certification body. Of the 20 anti-virus product tested, 35 per cent failed to meet the test's criteria. Six of the failing grades were caused by so called false positives, legitimate files that are incorrectly flagged as malware." The OS may well take full advantage of 4gb, but do the games? "Noddy" <SPAM@BLOCKER.ACTIVE> wrote in message news:xZHsi.39038$JO6.15513@fe02.news.easynews.com... > "Mike Hall - MVP" <mikehall@mvps.org> wrote in message > news:e2STpcd1HHA.5980@TK2MSFTNGP04.phx.gbl... >> Yes, there are issues. What you have heard is correct. Unless you have to >> run mission critical 64bit apps requiring greater than 4gb, you are best >> to stay with the 32bit OS.. > > I'm running Vista64 and AVG antivirus works fine and so do the games I > have installed so far. I have 4gb of ram and want the OS to have full > access to it. -- Mike Hall MS MVP Windows Shell/User http://msmvps.com/blogs/mikehall/ |
| | #7 (permalink) |
| | Re: 32bit vs 64bit "> Pay your money and take your choice. You need 64bit motherboard, processor > and 2gb Ram to make the 64 worth while of course. > Hi The new machine is a Core 2 Quad CPU (Q6600) with a motherboard supporting it so it will support 64 bit just fine, but since there will (at the current time) be issues with appliactions and AV software with 64 bit OS I might as well continue with 32 bit. My main applications are visualstudio (32 bit) Vmware (32 bit) and some games. As long as I only have 2gb ram the limit of ram that the OS can adresse is well within the boundries of my setup. /A. |
| | #8 (permalink) |
| | Re: 32bit vs 64bit On Fri, 3 Aug 2007 15:00:22 +0100, "Ian Betts" <igb123@talktalk.net> wrote: > > > "Andy" <andy@blocker.com> wrote in message > news:74E40EA9-1522-4EC0-9C23-039D528D89F3@microsoft.com... > > Hi > > > > Just getting ready to setup my new Vista machine, but I'm a bit uncertain > > about if I'm going for 32bit or 64bit. I actually have access to both > > versions. I've heard that there are issues with 64 bit, such as antivirus, > > games and so on. Are there actually any real benefits for 64bit at the > > moment, besides support for more memory. > > I'm very happy for arguments for both options. > > > > /A. > > > > > > > Pay your money and take your choice. You need 64bit motherboard, processor > and 2gb Ram to make the 64 worth while of course. Over and above what hardware you have, you need 64-bit drivers for all your hardware (and there are many cases where the drivers aren't available) to make it work at all. Then, to make it worthwhile, you need 64-bit applications, of which there are presently very few. Without the 64-bit applications, any performance improvement will be so small as to be almost unnoticeable. A few years from now, almost everybody will be running 64-bit Windows. But for the present, it's a rare person for whom it makes sense, even if you have the hardware to support it. -- Ken Blake, Microsoft MVP Windows - Shell/User Please Reply to the Newsgroup |
| | #9 (permalink) |
| | Re: 32bit vs 64bit If you're doing VMWare, I suggest going with 64 bit. That is the main reason I built my new dual quad-core Xeon PC that I run Vista Ultimate X64 on. Virtual PC hosts, either from Microsoft tools or VMWare tools, require a lot of memory. My 8GB, so far, allow me to run as many as a dozen or more virtual PC/Servers at the same time - and I still have 4 empty memory slots for another 8GB when I need it. I do have some problems with games, though. I am not a big gamer but I do like strategy games like Age of Empires, etc. The only game I have tried to install on my Vista X64 is Age of Empires II and it will not complete the install. If you're like me, though, you probably have more than one PC anyway so I play Age of Empires II on my Core 2 Duo Vista X86 box. But writing this post gave me the idea to try Age of Empires on a virtual PC running XP Pro. Dale -- Dale Preston MCAD C# MCSE, MCDBA "Andy" wrote: > > "> Pay your money and take your choice. You need 64bit motherboard, > processor > > and 2gb Ram to make the 64 worth while of course. > > > Hi > > The new machine is a Core 2 Quad CPU (Q6600) with a motherboard supporting > it so it will support 64 bit just fine, but since there will (at the current > time) be issues with appliactions and AV software with 64 bit OS I might as > well continue with 32 bit. My main applications are visualstudio (32 bit) > Vmware (32 bit) and some games. As long as I only have 2gb ram the limit of > ram that the OS can adresse is well within the boundries of my setup. > > /A. > |
| | #10 (permalink) |
| | Re: 32bit vs 64bit I didn't have any problem at all with 64-bit drivers for my hardware. With the exception of Creative Labs, most well-known hardware vendors are providing working 64-bit Vista drivers for their current hardware. And I haven't had any problem at all with any of my productivity software; only with my productivitiy-killer software. -- Dale Preston MCAD C# MCSE, MCDBA "Adam Albright" wrote: > On Fri, 3 Aug 2007 15:47:56 +0200, "Andy" <andy@blocker.com> wrote: > > >Hi > > > >Just getting ready to setup my new Vista machine, but I'm a bit uncertain > >about if I'm going for 32bit or 64bit. I actually have access to both > >versions. I've heard that there are issues with 64 bit, such as antivirus, > >games and so on. Are there actually any real benefits for 64bit at the > >moment, besides support for more memory. > >I'm very happy for arguments for both options. > > > >/A. > > > The only advantage to using 64 bit at THIS TIME is if you have both > the hardware and it's drivers plus software that actually take > advantage of it. For most people that isn't a reality...yet. > > A pretty good analogy would be if you could, buying a hydrogen > car now. Likely it would stay in your garage since there are few > places to buy hydrogen fuel. A good idea and the future, but too > early. Ditto for 64 bit. > > |
| I have dual boot PC [VISTA 32BIT & 64BIT]---problems only in 64bit vista drivers | Drivers | |||
| In a 64bit PC may make 4 partitions vista 32bit, vista 64bit, and ... | Virtual PC | |||
| 64bit PC MACHINE, X86 WINDOWS,CAN I have 32bit & 64bit vista partitions | General Discussion | |||
| 32bit or 64bit ? | Vista General | |||
| switching from 64bit to 32bit now then back to 64bit later | Vista installation & setup | |||
