Vista - Downgrade from Vista Home Premium to Home Basic
Old 03-12-2008   #11 (permalink)
kurttrail
Re: Downgrade from Vista Home Premium to Home Basic
din wrote:
Quote:
> hi everyone,
> I think I've same problem here.
> Before this i use vista home premium but after several updating trough
> online updating by microsoft, my OS became vista home basic. When i
> check the themes, theme for windows aero is not existing anymore.
> besides that, the resolution for my lap-top changed and I can't repair
> it because the file is lost and there only two types either highest or
> medium resolution.
> my screen saver cannot work also.
> this happen after my last upgrading 2 days ago.
> I hope someone can help me to solve this problem, or should I re-format
> my device ??
Sounds like whatever "upgrading" you did 2 days ago, killed you video
driver. Most likely all you need to do is delete/uninstall any remenant
of your old video driver, reboot, and then install the latest driver for
your video card/chipset.
That you don't already know this, means that you probably don't have
enough computer expertise to "re-format," even if it were necessary.
Peace!
Kurt
Former Self-anointed Moderator
microscum.pubic.windowsexp.gonorrhea
"Produkt-Aktivierung macht frei!"
Windows Vista Home Premium Key Home Basic Discs General Discussion
ip4200: Vista Home Basic Fails, but Home premium works Vista print fax & scan
Re: Anytime Upgrade from Vista Home Basic to Home Premium Vista installation & setup
Downgrade from Home Premium to Home Basic? Vista General
Downgrade Vista Home Premium to XP Home Vista installation & setup
