| | Slow USB connection and network transfer Hi I have done a fresh Vista 32 bit install on my Dell Precision 690 (2Gb RAM) and have found a few things that cause concern: 1) The USB connection is painfully slow - I connect my camera to download pictures and it is upto 50 times slow than under XP and it often times out. 2) The Vista PC seems to hog the server connection for up to 30 minutes after a boot, causing other PCs on the same hub to lose their connection (admittedly via home hub but it never happened with XP) 3) Trouble downloading larger files from the internet. Any help or advice would be appreciated. Thanks Andy |
| | Re: Slow USB connection and network transfer "Andy W" <AndyW@discussions.microsoft.com> wrote in message news:65D98301-66C0-4ED9-B87F-22A05658FEED@microsoft.com... > Hi > > I have done a fresh Vista 32 bit install on my Dell Precision 690 (2Gb > RAM) > and have found a few things that cause concern: > > 1) The USB connection is painfully slow - I connect my camera to download > pictures and it is upto 50 times slow than under XP and it often times > out. > > 2) The Vista PC seems to hog the server connection for up to 30 minutes > after a boot, causing other PCs on the same hub to lose their connection > (admittedly via home hub but it never happened with XP) > > 3) Trouble downloading larger files from the internet. > > Any help or advice would be appreciated. > > Thanks > > Andy > You may need to update USB drivers for Vista. Your motherboard supplier site would have them on Dell online may help in the support section. You need to find out what runs at boot up that is not on your XP. Vista itself does not use the internet at start only the setting you have selected, Such as virus protection. How many computers are you running on the hub and are they all wireless or Ethernet cabled. Each one has to share the same line and take it's turn. You may need to insert a switch in the network to sort out log jams. -- Ian |
| | Re: Slow USB connection and network transfer * Andy W: > Hi > > I have done a fresh Vista 32 bit install on my Dell Precision 690 (2Gb RAM) and have found a > few things that cause concern: > > 1) The USB connection is painfully slow - I connect my camera to download pictures and it is > upto 50 times slow than under XP and it often times out. > > 2) The Vista PC seems to hog the server connection for up to 30 minutes after a boot, > causing other PCs on the same hub to lose their connection (admittedly via home hub but it > never happened with XP) > > 3) Trouble downloading larger files from the internet. > > Any help or advice would be appreciated. Andy, For your USB problems, go here https://support.microsoft.com/contac...1410&WS=hotfix Request the hotfix for KB article number 936003 They will email you a link to download the hotfix. The link below talks about the update. http://support.microsoft.com/default...b;en-us;936003 Microsoft has released a cumulative update rollup for Windows Vista. This rollup helps establish a quality baseline for the USB core components on the Windows Vista operating system. This rollup supersedes previously-released USB fixes and contains additional high-applicability USB fixes. Also- what router are you using? Is it an older or newer one? -Michael |
| SP1 didn't fix slow network transfer? | Vista networking & sharing | |||
| network slow text file transfer | Network & Sharing | |||
| Slow incoming but fast outgoing network transfer | Network & Sharing | |||
| Very slow network connection to 64 bit server | Vista networking & sharing | |||
| Slow network connection | Vista networking & sharing | |||
