Vista - Right click menu
Old 08-04-2007   #1 (permalink)
Kevin
Right click menu
Is there a way to add options to the right click menu? I am using PC- Cillin
for Virus protection. To scan a file for a virus I have to first open
PC-Cillin and then drag the files to the main PC-Cillin window to scan them.
Any other program I have used had an option to scan for virus from the right
click menu.
Thanks
Old 08-04-2007   #2 (permalink)
Spirit
Re: Right click menu
http://www.google.com/search?hl=en&q...ght+click+menu
See 4th Entry here
http://www.nirsoft.net/utils/shexview.html
Shell Extensions Manager - Right Click and more
"Kevin" <Kevin@discussions.microsoft.com> wrote in message
news:A1705CE1-1135-4FDA-8E2A-F6A6F6C7A414@microsoft.com...
> Cillin
> them.
> right
> click menu.
> Thanks
Old 08-05-2007   #3 (permalink)
Ian Betts
> Cillin
> them.
> right
> click menu.
> Thanks
Just right click Start, open Explore and scan down to SendTo. Drag and drop
the PG-Cillin to that folder.
Ian
right click menu General Discussion
Right click menu gone General Discussion
right click menu Vista General
Start Menu "right" click context menu Vista General
right-click menu Vista General
