Vista Tutorial - Display problems with certain websites II
Old 08-05-2007   #11 (permalink)
keepout@yahoo.com.invalid
Guest
Re: Display problems with certain websites II
On Sun, 05 Aug 2007 10:52:53 -0700, "Pete d'Oronzio [pdmagic]" <myfirstname@pdmagic.com> wrote:
>Spirit wrote:
>> I suspect you have something corrupting your data stream such as a
>> bad modem, router, possibly firewall and maybe even anti-virus.
>> Close all the programs you can and try again. Hardware issues are
>> tougher to troubleshoot without extra hardware.
>Thanks for your suggestions.
>I'll try setting up my laptop outside the firewall just after the dsl
>modem. However, what could explain that an XP VM *running inside*
>Vista would work? Also, that *every* non-Vista system on the network
>functions correctly?
>I mean, if I go outside the firewall and it works; and then I change
>the dsl modem/router and it works inside; Then what sort of thing
>could be happening that allows all other OS's to work except Vista?
UAC... internal security, M$ firewall, list goes on and on. Hit the troubleshooting links that come up on those 404 pages. Then remember they're there because they CAN cure your problem if you use them.
I'm pretty sure there's nothing wrong with my router, but on one specificpage today, my suggestion above cleared the 404 by fixing the router incompatibility.
I wouldn't call Vista bulletproof. It's as fallible as the next when you install crap software. Even stuff that passes M$ muster is still no guarantee.
more pix @ http://members.toast.net/cbminfo/index.html
Old 08-05-2007   #12 (permalink)
Guest
> use them.
Sure would love to, but the pages come up ok - just things they
reference don't. (i.e. images, stylesheets, etc.)
> specific page today, my suggestion above cleared the 404 by fixing
What did this? Clicking one of those 404 links? Fixed a route
incompatibility? Please elaborate, that sounds interesting.
bulletproof? ha! I'm not here to bash Vista - that's pointless.
It's not spitballproof, but I don't expect it to be. That's why I'm
here looking for help to fix / workaround a problem.
Obviously, I'm stunned that no one else (save that one post I
mentioned) has seen this.
Thanks,
-Pete
Old 08-06-2007   #13 (permalink)
Guest
On Sun, 05 Aug 2007 15:45:19 -0700, "Pete d'Oronzio [pdmagic]" <myfirstname@pdmagic.com> wrote:
>> use them.
error pages with vista come up with several links on troubleshooting, butif like me you're used to the worthless 404 pages, you gave up, closed the page and moved on.
With vista those 404's also have some trouble shooting tips, and 2 links on them. Since I've used those links, on those links I really want to see, and I'm pretty sure it's not just multitasked to the max. I hit those links, and it almost always finds something.
1 today said the page and my router ????? had an incompatibility and asked if I wanted to fix it. I have never figured out that reasoning. YesI want it fixed, or I wouldn't be here.
It did a few seconds of progress bar, and refreshed a good page vs a 404.
You say parts of the page. Your HOSTS file may be blocking these things ?I use a special hosts that also does this. It came with a block on missingchildren.com. I spent months trying to figure out why my missing children banner no longer worked even at the main web site.
I see missing bit's and pieces of pages [404] to crap ads all the time. That means my HOSTS is doing it's job.
C:\WINDOWS\System32\drivers\etc]hosts
check your hosts file for those 404's.
It may be perfectly normal.
Old 08-06-2007   #14 (permalink)
Guest
Spirit wrote:
> The problem could be a router on your leg of the internet and
> it has not been found yet by the providers.
Changed my router.
Still only works 10% of the time. msn.com and microsoft.com included.
Don't get any diagnostics (as the page itself loads)
bummer
-Pete
Old 08-09-2007   #15 (permalink)
Guest
Still not solved. In fact, I'm seeeing it occur on an XP box as well.
I've posted a summary of what I've found so far on this page:
http://research.pdmagic.com/test/vistaIE7/
.... welcoming any ideas....
Thanks,
-Pete
Old 08-09-2007   #16 (permalink)
Guest
On Thu, 09 Aug 2007 08:48:00 -0700, "Pete d'Oronzio [pdmagic]" <myfirstname@pdmagic.com> wrote:
There is something else, but IE uses it as a test bed for addon's.
START - ACCESSORIES - SYSTEM TOOLS - Internet explorer [no add-ons] I suspect a bare bones IE. If this works, your other problems may be configuration.
If the bare IE works, Not sure how to get your regular IE back to basics.
next
tools - Internet options - advanced - restore advanced settings and reset.
Tells you directly below it, you only do this if the browser is in an unusable state.
I'd say yours qualifies.
I'd also check all the tabs on tools - Internet options and restore all them to default status and see what happens. Add a reboot and try again.
Old 08-09-2007   #17 (permalink)
Guest
Tried that - and recall that I get the same behaviour in Safari.
Thanks.
-Pete
Old 08-10-2007   #18 (permalink)
Guest
On Thu, 09 Aug 2007 12:30:02 -0700, "Pete d'Oronzio [pdmagic]" <myfirstname@pdmagic.com> wrote:
I assume that means useless.
Here's something I've been fiddling with a lot lately.
But it doesn't match your problem, But with luck, it might fix things broad enough to fix yours also..
find a 404 page.
1st link troubleshoot connection. My router has been causing some problems, but normally just with over tasking. The serial - DSL connection is always the 1st thing to go if I multi task.
This troubleshoot thing has been finding problems constantly on SOME pages. Sometimes it resets things, others not. When it comes up with a 404 and it found nothing and asks to send a report off to M$, I know the machine has done it's best, and a report won't accomplish anything.
You could try Sam Spade on those pages that are crap and get more info onthem. They might actually have more troubles.
But you having the problem on different machines makes no sense.
Old 08-10-2007   #19 (permalink)
dean-dean
Guest
Is this the article you saw? It might be relevant:
Windows Vista cannot obtain an IP address from certain routers or from
certain non-Microsoft DHCP servers->
http://support.microsoft.com/kb/928233/en-us
"Pete d'Oronzio [pdmagic]" <myfirstname@pdmagic.com> wrote in message
news:ugsYqd31HHA.5164@TK2MSFTNGP05.phx.gbl...
> Spirit wrote:
>> Try Start - All Programs - Accessories - System Tools - IE without
>> Add-ons
>> If that woks you have BHO's and/or running programs causing your
>> issues.
> Same result. Still displays incorrectly.
> Recall this is a fresh install of Vista. There are no add-ins.
> Also, it works fine at other locations.
> Back in January when I first tried to install Vista and had this
> problem, I did a few searches to see if anyone else was experiencing
> this. I can't find the link anymore, but I swear there was an
> article somewhere that talked about Vista dealing with packets in a
> way that older routers couldn't handle. Is this possible?
> I've purchased a new dsl modem/router and plan to install next week
> to see if it fixes it. My ISP says no way it will change anything,
> but nothing wrong with getting something newer than my Cisco 678
> Thanks,
> -Pete
Old 08-10-2007   #20 (permalink)
Guest
> addon's. >> START - ACCESSORIES - SYSTEM TOOLS - Internet explorer
> [no add-ons]
> Hmm. is UAC on ?
> Run your machine thru www.GRC.com Shields up and see how your
> machine fares with that. It'll test your firewall connection
> specific to JUST you.
> And that's another thought. Other than me, it doesn't seem like
> you're getting much help in this group. I had the same problem
> with the ATI NG. Everyone had problems but no solutions.
> Try setting your news reader to news.grc.com. the name and password
> should be 1 and the same. then jump into the grc.techtalk group.
> I try not to over use that ng. But I can't recall not getting a fix
> from that group.
When I first installed 6 months ago I turned UAC off immediately.
SInce then, with the full wipe and reinstall, as well as install on
this new machine, I left UAC on. (however my account has
administrative privs)
www.grc.com had nothing to complain about except that it could ping
my gateway. green lights everywhere.
I'll have a look at that newgroup,because you are right - not much
info coming through here except for you. (though I've had dozens of
reads on the web page I posted. but no comments)
Thanks a lot for your time.
-Pete
Display Problems General Discussion
display problems Vista General
Display Problems Vista General
Display Problems on Certain Websites Vista General
"Internet Explorer cannot display the webpage" for some websites Vista General
