| Guest | Display problems with certain websites II Vista appears to be having a problem with my network. Some websites show up without properly loading stylesheets and/or images. It appears that perhaps it occurs when the resource is on a different server from the main page. The most obvious web page with this problem is microsoft.com! http://www.microsoft.com/en/us/default.aspx Another page that often fails: http://nytimes.com Here's what it looks like in IE 7 and in Safari on Vista: http://research.pdmagic.com/test/vis...rosoft_com.pdf Here you can see that .js and .css are loaded from different machine names: <script type="text/javascript" src="http://i3.microsoft.com/shared/core/1/js/library.js"> @import url('http://i2.microsoft.com/shared/core/1/css/core.css'); The problem is specific to Vista, and appears to be specific to my network. Here are the facts: 1. I installed Vista 32 Ultimate on my Laptop in January and experienced the problem, so uninstalled. 2. Recently installed Vista 64 Ultimate on my desktop and have the same problem. 3. Recently installed Vista 32 Ultimate on my laptop (again) - same problem. 4. There are about 6 computers in the office running XP, 2K, 2003 that do not have this problem. (running a variety of browsers including IE7) 5. I put a VMWare virtual machine on the Vista 64 desktop - XP pro in the VM. It doesn't have the problem. 6. I put the same VMWare XP Pro virtual machine on the laptop running Vista 32. Also doesn't have the problem. 7. Went to a different network and problem goes away completely. 8. Problem occurs on my network using wireless OR wired NIC's. 9. Other computers that work in the office are connected to same switch as the two that don't work. 10. The problem in intermittent. It works 10% of the time, fails 90% of the time. My network configuration is: DSL from Qwest Cisco 678 DSL Modem/Router GnatBox firewall software running on computer with Intel GB NIC's Netgear GB switch I'd like to install Vista on other systems in the office, but can't afford to have them fail on common web sites. Suggestions? Thanks, -Pete |
| Guest | Re: Display problems with certain websites II The "II" in the subject refers to this post by someone else: From: =?Utf-8?B?S0M=?= <KC@discussions.microsoft.com> Subject: Display Problems on Certain Websites Date: Tue, 26 Jun 2007 21:18:00 -0700 Message-ID: <2F80B22E-36D2-4211-A2E7-C147B9F26DFF@microsoft.com> Our problems seem similar. -Pete |
| Guest | Re: Display problems with certain websites II "Pete d'Oronzio [pdmagic]" <myfirstname@pdmagic.com> wrote in message news:#krehO21HHA.6128@TK2MSFTNGP02.phx.gbl... > Vista appears to be having a problem with my network. Some websites > show up without properly loading stylesheets and/or images. It > appears that perhaps it occurs when the resource is on a different > server from the main page. > > The most obvious web page with this problem is microsoft.com! > http://www.microsoft.com/en/us/default.aspx > > Another page that often fails: http://nytimes.com > > Here's what it looks like in IE 7 and in Safari on Vista: > http://research.pdmagic.com/test/vis...rosoft_com.pdf > > > Here you can see that .js and .css are loaded from different machine > names: > <script type="text/javascript" > src="http://i3.microsoft.com/shared/core/1/js/library.js"> > > @import url('http://i2.microsoft.com/shared/core/1/css/core.css'); > > The problem is specific to Vista, and appears to be specific to my > network. Here are the facts: > > 1. I installed Vista 32 Ultimate on my Laptop in January and > experienced the problem, so uninstalled. > 2. Recently installed Vista 64 Ultimate on my desktop and have the > same problem. > 3. Recently installed Vista 32 Ultimate on my laptop (again) - same > problem. > 4. There are about 6 computers in the office running XP, 2K, 2003 > that do not have this problem. (running a variety of browsers > including IE7) > 5. I put a VMWare virtual machine on the Vista 64 desktop - XP pro in > the VM. It doesn't have the problem. > 6. I put the same VMWare XP Pro virtual machine on the laptop running > Vista 32. Also doesn't have the problem. > 7. Went to a different network and problem goes away completely. > 8. Problem occurs on my network using wireless OR wired NIC's. > 9. Other computers that work in the office are connected to same > switch as the two that don't work. > 10. The problem in intermittent. It works 10% of the time, fails 90% > of the time. > > My network configuration is: > DSL from Qwest > Cisco 678 DSL Modem/Router > GnatBox firewall software running on computer with Intel GB NIC's > Netgear GB switch > > I'd like to install Vista on other systems in the office, but can't > afford to have them fail on common web sites. > > Suggestions? > > Thanks, > > -Pete > > Frankly after all those attempts to install I would format and start a clean install on all of them.. -- Ian With patience there is always a way. Please Reply to Newsgroup so all can read. Requests for assistance by email can not and will be deleted. |
| Guest | Re: Display problems with certain websites II Ian Betts wrote: > > > "Pete d'Oronzio [pdmagic]" <myfirstname@pdmagic.com> wrote in > message news:#krehO21HHA.6128@TK2MSFTNGP02.phx.gbl... > > Vista appears to be having a problem with my network. Some > > websites show up without properly loading stylesheets and/or > > images. It appears that perhaps it occurs when the resource is on > > a different server from the main page. > > > > The most obvious web page with this problem is microsoft.com! > > http://www.microsoft.com/en/us/default.aspx > > > > Another page that often fails: http://nytimes.com > > > > Here's what it looks like in IE 7 and in Safari on Vista: > > http://research.pdmagic.com/test/vis...rosoft_com.pdf > > > > > > Here you can see that .js and .css are loaded from different > > machine names: > > <script type="text/javascript" > > src="http://i3.microsoft.com/shared/core/1/js/library.js"> > > > > @import url('http://i2.microsoft.com/shared/core/1/css/core.css'); > > > > The problem is specific to Vista, and appears to be specific to my > > network. Here are the facts: > > > > 1. I installed Vista 32 Ultimate on my Laptop in January and > > experienced the problem, so uninstalled. > > 2. Recently installed Vista 64 Ultimate on my desktop and have the > > same problem. > > 3. Recently installed Vista 32 Ultimate on my laptop (again) - > > same problem. > > 4. There are about 6 computers in the office running XP, 2K, 2003 > > that do not have this problem. (running a variety of browsers > > including IE7) > > 5. I put a VMWare virtual machine on the Vista 64 desktop - XP > > pro in the VM. It doesn't have the problem. > > 6. I put the same VMWare XP Pro virtual machine on the laptop > > running Vista 32. Also doesn't have the problem. > > 7. Went to a different network and problem goes away completely. > > 8. Problem occurs on my network using wireless OR wired NIC's. > > 9. Other computers that work in the office are connected to same > > switch as the two that don't work. > > 10. The problem in intermittent. It works 10% of the time, fails > > 90% of the time. > > > > My network configuration is: > > DSL from Qwest > > Cisco 678 DSL Modem/Router > > GnatBox firewall software running on computer with Intel GB NIC's > > Netgear GB switch > > > > I'd like to install Vista on other systems in the office, but > > can't afford to have them fail on common web sites. > > > > Suggestions? > > > > Thanks, > > > > -Pete > > > > > Frankly after all those attempts to install I would format and > start a clean install on all of them.. These are *all* clean installs. Every single one of them. That's two virtual machines and two physical machines. They didn't work at the end of the install, or after applying MS patches. And - at least 2 of the 4 (the laptop and its VM) work fine at another location. Also, the laptop running an XP VM works fine on my network. Thanks, -Pete |
| Guest | Re: Display problems with certain websites II Try Start - All Programs - Accessories - System Tools - IE without Add-ons If that woks you have BHO's and/or running programs causing your issues. "Pete d'Oronzio [pdmagic]" <myfirstname@pdmagic.com> wrote in message news:%23njDvK31HHA.3640@TK2MSFTNGP06.phx.gbl... > Ian Betts wrote: > >> >> >> "Pete d'Oronzio [pdmagic]" <myfirstname@pdmagic.com> wrote in >> message news:#krehO21HHA.6128@TK2MSFTNGP02.phx.gbl... >> > Vista appears to be having a problem with my network. Some >> > websites show up without properly loading stylesheets and/or >> > images. It appears that perhaps it occurs when the resource is on >> > a different server from the main page. >> > >> > The most obvious web page with this problem is microsoft.com! >> > http://www.microsoft.com/en/us/default.aspx >> > >> > Another page that often fails: http://nytimes.com >> > >> > Here's what it looks like in IE 7 and in Safari on Vista: >> > http://research.pdmagic.com/test/vis...rosoft_com.pdf >> > >> > >> > Here you can see that .js and .css are loaded from different >> > machine names: >> > <script type="text/javascript" >> > src="http://i3.microsoft.com/shared/core/1/js/library.js"> >> > >> > @import url('http://i2.microsoft.com/shared/core/1/css/core.css'); >> > >> > The problem is specific to Vista, and appears to be specific to my >> > network. Here are the facts: >> > >> > 1. I installed Vista 32 Ultimate on my Laptop in January and >> > experienced the problem, so uninstalled. >> > 2. Recently installed Vista 64 Ultimate on my desktop and have the >> > same problem. >> > 3. Recently installed Vista 32 Ultimate on my laptop (again) - >> > same problem. >> > 4. There are about 6 computers in the office running XP, 2K, 2003 >> > that do not have this problem. (running a variety of browsers >> > including IE7) >> > 5. I put a VMWare virtual machine on the Vista 64 desktop - XP >> > pro in the VM. It doesn't have the problem. >> > 6. I put the same VMWare XP Pro virtual machine on the laptop >> > running Vista 32. Also doesn't have the problem. >> > 7. Went to a different network and problem goes away completely. >> > 8. Problem occurs on my network using wireless OR wired NIC's. >> > 9. Other computers that work in the office are connected to same >> > switch as the two that don't work. >> > 10. The problem in intermittent. It works 10% of the time, fails >> > 90% of the time. >> > >> > My network configuration is: >> > DSL from Qwest >> > Cisco 678 DSL Modem/Router >> > GnatBox firewall software running on computer with Intel GB NIC's >> > Netgear GB switch >> > >> > I'd like to install Vista on other systems in the office, but >> > can't afford to have them fail on common web sites. >> > >> > Suggestions? >> > >> > Thanks, >> > >> > -Pete >> > >> > >> Frankly after all those attempts to install I would format and >> start a clean install on all of them.. > > These are *all* clean installs. Every single one of them. That's > two virtual machines and two physical machines. They didn't work at > the end of the install, or after applying MS patches. > > And - at least 2 of the 4 (the laptop and its VM) work fine at > another location. Also, the laptop running an XP VM works fine on my > network. > > Thanks, > > -Pete |
| | #6 (permalink) |
| Guest | Re: Display problems with certain websites II Spirit wrote: > Try Start - All Programs - Accessories - System Tools - IE without > Add-ons > > If that woks you have BHO's and/or running programs causing your > issues. > Same result. Still displays incorrectly. Recall this is a fresh install of Vista. There are no add-ins. Also, it works fine at other locations. Back in January when I first tried to install Vista and had this problem, I did a few searches to see if anyone else was experiencing this. I can't find the link anymore, but I swear there was an article somewhere that talked about Vista dealing with packets in a way that older routers couldn't handle. Is this possible? I've purchased a new dsl modem/router and plan to install next week to see if it fixes it. My ISP says no way it will change anything, but nothing wrong with getting something newer than my Cisco 678 Thanks, -Pete |
| | #7 (permalink) |
| Guest | Re: Display problems with certain websites II I suspect you have something corrupting your data stream such as a bad modem, router, possibly firewall and maybe even anti-virus. Close all the programs you can and try again. Hardware issues are tougher to troubleshoot without extra hardware. "Pete d'Oronzio [pdmagic]" <myfirstname@pdmagic.com> wrote in message news:ugsYqd31HHA.5164@TK2MSFTNGP05.phx.gbl... > Spirit wrote: > >> Try Start - All Programs - Accessories - System Tools - IE without >> Add-ons >> >> If that woks you have BHO's and/or running programs causing your >> issues. >> > > Same result. Still displays incorrectly. > > Recall this is a fresh install of Vista. There are no add-ins. > Also, it works fine at other locations. > > Back in January when I first tried to install Vista and had this > problem, I did a few searches to see if anyone else was experiencing > this. I can't find the link anymore, but I swear there was an > article somewhere that talked about Vista dealing with packets in a > way that older routers couldn't handle. Is this possible? > > I've purchased a new dsl modem/router and plan to install next week > to see if it fixes it. My ISP says no way it will change anything, > but nothing wrong with getting something newer than my Cisco 678 > > Thanks, > > -Pete |
| | #8 (permalink) |
| Guest | Re: Display problems with certain websites II The problem could be a router on your leg of the internet and it has not been found yet by the providers. "Pete d'Oronzio [pdmagic]" <myfirstname@pdmagic.com> wrote in message news:ugsYqd31HHA.5164@TK2MSFTNGP05.phx.gbl... > Spirit wrote: > >> Try Start - All Programs - Accessories - System Tools - IE without >> Add-ons >> >> If that woks you have BHO's and/or running programs causing your >> issues. >> > > Same result. Still displays incorrectly. > > Recall this is a fresh install of Vista. There are no add-ins. > Also, it works fine at other locations. > > Back in January when I first tried to install Vista and had this > problem, I did a few searches to see if anyone else was experiencing > this. I can't find the link anymore, but I swear there was an > article somewhere that talked about Vista dealing with packets in a > way that older routers couldn't handle. Is this possible? > > I've purchased a new dsl modem/router and plan to install next week > to see if it fixes it. My ISP says no way it will change anything, > but nothing wrong with getting something newer than my Cisco 678 > > Thanks, > > -Pete |
| | #9 (permalink) |
| Guest | Re: Display problems with certain websites II Spirit wrote: > I suspect you have something corrupting your data stream such as a > bad modem, router, possibly firewall and maybe even anti-virus. > Close all the programs you can and try again. Hardware issues are > tougher to troubleshoot without extra hardware. > Thanks for your suggestions. I'll try setting up my laptop outside the firewall just after the dsl modem. However, what could explain that an XP VM *running inside* Vista would work? Also, that *every* non-Vista system on the network functions correctly? I mean, if I go outside the firewall and it works; and then I change the dsl modem/router and it works inside; Then what sort of thing could be happening that allows all other OS's to work except Vista? -Pete |
| | #10 (permalink) |
| Guest | Re: Display problems with certain websites II Possibly a Vista Driver is corrupting your data flow and the XP VM does not use that particular part of the driver. "Pete d'Oronzio [pdmagic]" <myfirstname@pdmagic.com> wrote in message news:OpQlzl41HHA.1208@TK2MSFTNGP03.phx.gbl... > Spirit wrote: > >> I suspect you have something corrupting your data stream such as a >> bad modem, router, possibly firewall and maybe even anti-virus. >> Close all the programs you can and try again. Hardware issues are >> tougher to troubleshoot without extra hardware. >> > > Thanks for your suggestions. > > I'll try setting up my laptop outside the firewall just after the dsl > modem. However, what could explain that an XP VM *running inside* > Vista would work? Also, that *every* non-Vista system on the network > functions correctly? > > I mean, if I go outside the firewall and it works; and then I change > the dsl modem/router and it works inside; Then what sort of thing > could be happening that allows all other OS's to work except Vista? > > -Pete |
| Display Problems | General Discussion | |||
| display problems | Vista General | |||
| Display Problems | Vista General | |||
| Display Problems on Certain Websites | Vista General | |||
| "Internet Explorer cannot display the webpage" for some websites | Vista General | |||
