| Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks. |
| | LinkBack | Thread Tools | Display Modes |
| Guest | Display Problems Hello, Got a problem cant seem to figure it out. Upon boot up, I see little colored dots on the bios boot up screen. On the next screen where it checks DMI and whether or not it should boot from a cdroom, some of the words have changed letters such as instead of master disk, it says, Master Dick or have symbols in the letters. Instead of controller it says cntrolr. Stuff like that. When vista boots up, i have Lines that go through the screen, looks like the old snow lines on old televisions except they are colored. They also move when i move windows over them. Its very weird. It was working for a while. I then installed a 2nd dimm of Ram, same brand same model. It worked for a couple weeks and then it started. Heres my specs: Operating: Vista Ultimate X64 Mobo: GA-K8NE Processor: AMD Atholon 64 Processor 3000+ Video Card: Powercolor Radeon X1950 Pro memory: 2 X CORSAIR ValueSelect 1GB 184-Pin DDR SDRAM DDR 400 (PC 3200) any help would be appreciated! Thanks Rich |
| Guest | Re: Display Problems Did you go back to the old RAM configuration to see if the problem stops? Also, try reseating the video card. -- Steve Easton "Richard Wolff" <RichardWolff@discussions.microsoft.com> wrote in message news:42E436D3-4E50-40DD-B689-332C67B741D9@microsoft.com... > Hello, Got a problem cant seem to figure it out. > > Upon boot up, I see little colored dots on the bios boot up screen. On the > next screen where it checks DMI and whether or not it should boot from a > cdroom, some of the words have changed letters such as instead of master > disk, it says, Master Dick or have symbols in the letters. Instead of > controller it says cntrolr. Stuff like that. > > When vista boots up, i have Lines that go through the screen, looks like the > old snow lines on old televisions except they are colored. They also move > when i move windows over them. Its very weird. > > It was working for a while. I then installed a 2nd dimm of Ram, same brand > same model. It worked for a couple weeks and then it started. > > Heres my specs: > Operating: Vista Ultimate X64 > Mobo: GA-K8NE > Processor: AMD Atholon 64 Processor 3000+ > Video Card: Powercolor Radeon X1950 Pro > memory: 2 X CORSAIR ValueSelect 1GB 184-Pin DDR SDRAM DDR 400 (PC 3200) > > any help would be appreciated! > > Thanks > > Rich |
| Guest | Re: Display Problems Hi Richard-- Try replacing your video driver or updating it if there is a newer one for your card. Then: 1) Run an AV program and a spyware program like Adaware and Defender. 2) Run SFC. 3) If needed, and you have a Vista DVD run Startup Repair. SFC or System File Checker is a bit like the spare tire in your car or a backup battery I suppose. In Vista of course, they have changed it somewhat and come up with a new name--Redmond stands for name it something different twice a year and now it's part of WRP or Windows Resource Protection. It scans protected resources including thousands of files, libraries, critical folders, and essential registry keys, and it replaces those that are corrupted with intact ones. It fixes a lot of problems in Windows XP, OE, Windows Vista, Win Mail, IE6, and on Vista or if it is installed on XP, IE7. It protects these things from changes by any source including administrators, by keeping a spare of most of them. How to Run SFC: Type "cmd" into the Search box above the Start Button>and when cmd comes up at the top of the Start menu>right click cmd and click "run as Admin" and when the cmd prompt comes up at the cmd prompt type "sfc /scannow" no quotes and let it run. This may fix things quite a bit. It replaces corrupt files with intact ones, if you're not familiar with it. You can try a restore point to before this happened or you try the steps below if you have a Vista DVD: Pressing F8 repeatedly when you seem the firmware screen may be is a generic way to launch Windows RE on some OEM Vista computers. Startup Repair will look like this when you put in the Vista DVD: http://www.vistaclues.com/wp-content...r-computer.png You run the startup repair tool this way (and system restore from here is also sometimes effective): http://support.microsoft.com/kb/925810/en-us How To Run Startup Repair In Vista Ultimate (Multiple Screenshots) http://www.windowsvista.windowsreins...rtup/index.htm I'm going to give you a bunch of links and most of them you won't have to use, but they are alternative ways to fix Vista. Right now I want you to put in the DVD and restart. It will automatically take you to this on your screen: http://www.vistaclues.com/wp-content...r-computer.png That will allow you to go to the Vista setup that has a Repair link on the lower left corner>click it and then you'll see a gray backgrounded list and I want you to click Startup Repair from it and follow the directions. The gray screen after you click the first link in the above pic will look like this: http://www.windowsreinstall.com/winv...ir/Image17.gif Click Startup Repair, the link at the top and after it scans>click OK and let it try to repair Vista. It will tell you if it does, and if not This should work, but if not,then you can follow the alternative ways to fix this including booting into Safe Mode by tapping the F8 key and using System Restore. Directions and links for alternative ways to fix this are below, but I hope you won't need them: If you have any questions on getting the Startup Repair done, just post them. If you have a Vista DVD try Startup Repair. If that doesn't work, try SafeMode>System Restore from the Recovery Environment, and you always have the F8 advanced options ( five of them including Last Known Good Configuration) and a repair install (with the DVD) as well. In addition you can use the Bootsect tool to manually repair the boot sector by accessing the command prompt from the DVD or from F8 and typing at the prompt: ****Ten Methods to Repair BSOD No Boots or Serious Problems in Windows Vista**** ***Startup Repair and System Restore from the Win Recovery Environment on the DVD*** Although MSFT's Official Party Line as expressed by the Win RE team is that Startup Repair is only to fix startups, like a lot of features rtm'd that have broader application, so does Startup Repair. I have used it many times to fix major systemic problems in Vista when it would still boot successfully, and am talking with them to try to find out why they seem to bill it as only fixing startup problems. You can run Startup Repair by putting your Vista DVD in after theanguage screen in setup. You can also run System Restore from the same location. You run the startup repair tool this way (and system restore from here is also sometimes effective): http://support.microsoft.com/kb/925810/en-us How To Run Startup Repair In Vista Ultimate (Multiple Screenshots) http://www.windowsvista.windowsreins...rtup/index.htm Note The computer must be configured to start from a CD or from a DVD. For information about how to configure the computer to start from a CD or from a DVD, see the information that came with the computer. 2. Restart the computer. To do this, click Start, click the arrow next to the Lock button, and then click Restart. This usually means that you enter bios setup by whatever key or keys (sometimes there is more than one key that will do it for your model--go to pc manufacturer site) and configure CD to be first in the boot order (this will allow you to boot from the Vista DVD as well): See for ref: Access/Enter Motherboard BIOS (applies to Vista as well) http://www.michaelstevenstech.com/bios_manufacturer.htm Boot Order in Bios (Set Boot from HD 1st) http://www.short-media.com/images/mm...ios/bios03.jpg Good luck, CH "Richard Wolff" <RichardWolff@discussions.microsoft.com> wrote in message news:42E436D3-4E50-40DD-B689-332C67B741D9@microsoft.com... > Hello, Got a problem cant seem to figure it out. > > Upon boot up, I see little colored dots on the bios boot up screen. On the > next screen where it checks DMI and whether or not it should boot from a > cdroom, some of the words have changed letters such as instead of master > disk, it says, Master Dick or have symbols in the letters. Instead of > controller it says cntrolr. Stuff like that. > > When vista boots up, i have Lines that go through the screen, looks like > the > old snow lines on old televisions except they are colored. They also move > when i move windows over them. Its very weird. > > It was working for a while. I then installed a 2nd dimm of Ram, same brand > same model. It worked for a couple weeks and then it started. > > Heres my specs: > Operating: Vista Ultimate X64 > Mobo: GA-K8NE > Processor: AMD Atholon 64 Processor 3000+ > Video Card: Powercolor Radeon X1950 Pro > memory: 2 X CORSAIR ValueSelect 1GB 184-Pin DDR SDRAM DDR 400 (PC 3200) > > any help would be appreciated! > > Thanks > > Rich |
| Guest | Re: Display Problems Sounds like a display controller problem. Pull it out and clean the contacts and reinstall. Make sure it is fully seated in the connector. Post back and let us know if that fixes the problem. "Richard Wolff" <RichardWolff@discussions.microsoft.com> wrote in message news:42E436D3-4E50-40DD-B689-332C67B741D9@microsoft.com... > Hello, Got a problem cant seem to figure it out. > > Upon boot up, I see little colored dots on the bios boot up screen. On the > next screen where it checks DMI and whether or not it should boot from a > cdroom, some of the words have changed letters such as instead of master > disk, it says, Master Dick or have symbols in the letters. Instead of > controller it says cntrolr. Stuff like that. > > When vista boots up, i have Lines that go through the screen, looks like > the > old snow lines on old televisions except they are colored. They also move > when i move windows over them. Its very weird. > > It was working for a while. I then installed a 2nd dimm of Ram, same brand > same model. It worked for a couple weeks and then it started. > > Heres my specs: > Operating: Vista Ultimate X64 > Mobo: GA-K8NE > Processor: AMD Atholon 64 Processor 3000+ > Video Card: Powercolor Radeon X1950 Pro > memory: 2 X CORSAIR ValueSelect 1GB 184-Pin DDR SDRAM DDR 400 (PC 3200) > > any help would be appreciated! > > Thanks > > Rich |
| Display Modes | |
| display problems | Ron Kirschner | Vista General | 1 | 12-16-2007 05:44 PM |
| Display problems | jamepc | Graphic cards | 0 | 11-30-2007 10:55 PM |
| Display Problems???? HELP | Newkirk | Vista General | 1 | 07-26-2007 06:56 PM |
| Display problems | m4r | Vista General | 1 | 07-12-2007 01:18 AM |
