| Guest | 1 Drive/ 2 OS problem I dont know what I messed up, but then to fix it I tried to reinstall Vista. Now when I restart I get a black screen that asks which "Microsoft vista" I want. Selecting either choice brings me to the same log-in screen and has none of my old files. How do I remove one of the choices and get back to a normal startup? |
| Guest | Re: 1 Drive/ 2 OS problem Hi, Click start, type msconfig and hit <enter>. Go to the boot tab, click on the unneeded entry and delete it. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Carson1233" <Carson1233@discussions.microsoft.com> wrote in message news:53643239-E8AE-45FF-B3B4-3638E8CE091F@microsoft.com... >I dont know what I messed up, but then to fix it I tried to reinstall >Vista. > Now when I restart I get a black screen that asks which "Microsoft vista" > I > want. Selecting either choice brings me to the same log-in screen and has > none of my old files. > How do I remove one of the choices and get back to a normal startup? |
| Guest | Re: 1 Drive/ 2 OS problem If you reinstalled Vista, rather than choosing to see if Vista could repair an existing installation, Vista deleted your My Documents folder. This has been a consistent and rather cruel fact of Microsoft OS installation life. Win9x and XP will do the same thing. If this is what you did your data is toast. You can try to run data retrieval software but most likely it has all been overwritten. Now you know why it is necessary to backup your files periodically to CD, DVD or a second hard drive. The other problem is the Vista boot loader. Yet again, dubious programming decisions by Microsoft make it essentially impossible to remove the thing unless you totally reformat your hard drive. Of course if you are so unwise as to reinstall Vista rather than a real OS, like XP, you will reinstall the wonderful Vista boot loader. However you can set Vista so you do not see that menu at boot time. It would be in your best interest to do some reading on the subject. |
| Guest | Re: 1 Drive/ 2 OS problem Follow Rick's advice. The other is just %$^%@^%$@$ "Carson1233" <Carson1233@discussions.microsoft.com> wrote in message news:53643239-E8AE-45FF-B3B4-3638E8CE091F@microsoft.com... >I dont know what I messed up, but then to fix it I tried to reinstall >Vista. > Now when I restart I get a black screen that asks which "Microsoft vista" > I > want. Selecting either choice brings me to the same log-in screen and has > none of my old files. > How do I remove one of the choices and get back to a normal startup? |
| Combo RAID1 and standard Drive setup problem - Unallocated Drive | General Discussion | |||
| DVD-RW drive problem | Vista hardware & devices | |||
| Problem with my DVD-drive | General Discussion | |||
| Problem with DVD/CD RW drive | Vista hardware & devices | |||
| Vista drive has problem, want to copy files to new drive, HOW?? | Vista security | |||
