| | Re: HELP! Download Problems Hi ringsofterror. Before a downloaded file is transferred to your chosen folder location, its parts, so to speak, are downloaded to the Temporary Internet Files folder. Try this. Go to IE7 > Tools > Internet Options, and, on the General tab, click on Settings, under the "Browsing history" section. In the new window, next to "Disk space to use", try putting it at an amount at least half of the highest number of what it says as "(Recommended)"; for example, if it says 50- 250MB, try at least 125MB (the default is 50, which is usually enough for browsing). Click OK. Back on the General tab, under "Browsing history" again, click on Delete, then click on Temporary Internet Files. Try a download again. "ringsofterror" <ringsofterror@discussions.microsoft.com> wrote in message news:B5C3813E-5BBF-4832-B4C7-7754E10D8F99@microsoft.com... > Hey I got my new Dell Computer August 3rd and I don't have that many > errors. > There is one that I have to fix though. Whenever I try to download > something > it only does so much unless it's a small download but anything over 5MB > won't > work. It is very annoying. Can anyone help? |
| HELP! Download Problems | Vista General | |||
| download problems | Vista General | |||
| RC1 Download problems | Vista General | |||
