Vista Forums Home Join Vista Forums Donate Windows 7 Forum Vista Tutorials Tags
Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks.
Product Problems with Vista
LinkBack Thread Tools Display Modes
Old 08-06-2007   #1 (permalink)
Tom
Guest
Hi, I've recently bought a new Medion Tower complete with Vista but whenever
I try to enter my proudct key for Office it rejects it, I've written it down
many times and it just refuses my product key. Its a 25 alphunumeric key that
I found on a label on the back of my tower with Microsoft written on it.
Thanks Tom
Old 08-06-2007   #2 (permalink)
Myweb
Guest
Re: Product Problems with Vista
Hello Tom,
On the machine normally is the key for Vista, so check the label if it is
really for Office. If yes, just contact MS support, they will help you.
Best regards
Myweb
Disclaimer: This posting is provided "AS IS" with no warranties, and confers
no rights.
> whenever I try to enter my proudct key for Office it rejects it, I've
> written it down many times and it just refuses my product key. Its a
> 25 alphunumeric key that I found on a label on the back of my tower
> Thanks Tom
Old 08-06-2007   #3 (permalink)
grege
Guest
Sounds like you are typing in the Vista OS key, not the Office key.
Check your Office packaging for the correct key
"Tom" <Tom@discussions.microsoft.com> wrote in message
news:C73FE61B-D2B6-417B-AD4B-71F3168E1312@microsoft.com...
> whenever
> down
> that
> Thanks Tom
Old 08-06-2007   #4 (permalink)
Rick Rogers
Guest
The Product Key on the tower likely is for Windows Vista, not Office. You
will need to check your documentation that came with the system as to the
location of an Office key. You may have a trial version that requires the
purchase of a key.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
> whenever
> down
> that
> Thanks Tom
Display Modes
Product Key Problems Robert Vista installation & setup 2 02-28-2008 09:56 PM
Product Key problems Nan Vista account administration 1 01-26-2008 08:55 PM
product key problems wanda Vista General 1 06-22-2007 10:43 PM
Annoying product key problems Dan Smith Vista hardware & devices 4 04-01-2007 06:06 PM
Product ID problems Mark Vista General 21 02-28-2007 06:17 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
