| Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks. |
| | LinkBack | Thread Tools | Display Modes |
| Guest | Konica 7022 vista problem Hello, I have a Konica 7022 printer connected to the network. It works very well with computers on XP and 2000 but when I tried install it on Vista it showed: "windows cannot connect to the printer" Error: 0x0000000d. I tried also to install it by the localport (\\server\printer) but it also does not work. Where is the problem? This Vista does not have any problems with shared files/directories, so this is not the point. I also turned off the firewall. Thanks for your help! P. |
| Display Modes | |
| Trouble getting Konica Minolta PagePro 1350w to work with vista x6 | lclemjr | Vista print fax & scan | 2 | 02-23-2008 01:44 AM |
| Konica Minolta 2400W printer problem | Weird Harold | Vista hardware & devices | 3 | 10-15-2007 12:17 AM |
| konica minolta bizhub 162 on vista x64 | majer ;) | Vista print fax & scan | 2 | 05-25-2007 10:22 AM |
| Konica 7013 | Frank Delporte | Vista print fax & scan | 1 | 05-21-2007 10:27 AM |
| konica dl 2400/2430 | Rex Geissinger | Vista print fax & scan | 3 | 02-02-2007 05:13 PM |
