| | #11 (permalink) |
| Administrator | Re: Customize Vista's System Restore? In Windows XP, I could customize each drive to have a non-default size (low as 200 MB), disable, or enable for the system restore feature. In Vista, I cannot customize each drive. I can only enable and disable it. Did I miss this option in Vista? Thank you in advance. ![]() -- Phillip Pi Senior Software Quality Assurance Analyst ISP/Symantec Online Services, Consumer Business Unit Symantec Corporation Symantec Corp. ----------------------------------------------------- Email: phillip_pi@symantec.comSYMC (remove SYMC to reply by e-mail) ----------------------------------------------------- Please do NOT e-mail me for technical support. DISCLAIMER: The views expressed in this posting are mine, and do not necessarily reflect the views of my employer. Thank you. This will show you how to do with screenshots. System Restore - disk space Shawn |
| | #12 (permalink) |
| Guest | Re: Customize Vista's System Restore? Hi Phillip, How to adjust disk space in Windows Vista: http://bertk.mvps.org/html/diskspacev.html Regards, Bert Kinney MS-MVP Shell/User http://bertk.mvps.org Member: http://dts-l.org Phillip Pi wrote: > In Windows XP, I could customize each drive to have a non-default size > (low as 200 MB), disable, or enable for the system restore feature. In > Vista, I cannot customize each drive. I can only enable and disable it. > > Did I miss this option in Vista? > > Thank you in advance. ![]() |
| | #13 (permalink) |
| Guest | Re: Customize Vista's System Restore? Dudes, I have just read this and completed the nessecary steps. I asked a q in filling 30GB of space only to find that 14GB was restore points, see post "FILLED 30GB of SPACE". Think that this is a very handy tip and worth knocking the size down a fair bit. Top drawer stuff. Cheerz, Marcus |
| | #14 (permalink) |
| Administrator | Re: Customize Vista's System Restore? Dudes, I have just read this and completed the nessecary steps. I asked a q in filling 30GB of space only to find that 14GB was restore points, see post "FILLED 30GB of SPACE". Think that this is a very handy tip and worth knocking the size down a fair bit. Top drawer stuff. Cheerz, Marcus I'm glad it has helped you. Thank you for the feedback. Shawn |
| | #15 (permalink) |
| Guest | Re: Customize Vista's System Restore? You're welcome Marcus. Regards, Bert Kinney MS-MVP Shell/User http://bertk.mvps.org Member: http://dts-l.org marcusFZ6 wrote: > Dudes, I have just read this and completed the nessecary steps. I asked a q > in filling 30GB of space only to find that 14GB was restore points, see post > "FILLED 30GB of SPACE". > Think that this is a very handy tip and worth knocking the size down a fair > bit. Top drawer stuff. > Cheerz, Marcus |
| Customize System Restore intervals | Vista General | |||
| Vista's System Restore points format. | Vista General | |||
| Customize Vista's System Restore? | Vista file management | |||
| Customize Vista's System Restore? | Vista performance & maintenance | |||
| How good is Vista's System Restore | Vista performance & maintenance | |||
