| | Question about Vista 64-bit (a) Can you upgrade from Vista-32 bit to 64-bit without trashing your disks ? (b) I have the 32-bit disks, can I get the 64-bit disks cheaper than buying a new set ? |
| | Re: Question about Vista 64-bit You will have to do a clean install of Vista x64. If you got a retail version of Vista, there should be an enclosed coupon directing you to a web site to request the 64-bit version for a small (~$US 10.00) shipping fee by mail. And you can keep your 32-bit installation disks. -- I Bleed Blue and Gold GO BEARS! "Ian Semmel" <anyone@rocketcomp.com.au> wrote in message news:07055983A63449A28B6229862BB17E39@DIMITY... (a) Can you upgrade from Vista-32 bit to 64-bit without trashing your disks ? (b) I have the 32-bit disks, can I get the 64-bit disks cheaper than buying a new set ? |
| | Re: Question about Vista 64-bit The bigger question is WHY? Do you have a new piece of hardware or software that required 64-bit? Can you get 64-bit drivers for all of your hardware, both internal (video cards, etc.) and external printers, scanners, web cams, keyboard and mice? "Ian Semmel" <anyone@rocketcomp.com.au> wrote in message news:07055983A63449A28B6229862BB17E39@DIMITY... (a) Can you upgrade from Vista-32 bit to 64-bit without trashing your disks ? (b) I have the 32-bit disks, can I get the 64-bit disks cheaper than buying a new set ? |
| | Re: Question about Vista 64-bit This is a 64 bit age. I think it is about time the common operating system is 64 bits. The hardware vendors need to start supporting 64 bit. "Charles W Davis" <Anthemwebs@lvcoxmail.com> wrote in message news A61C0C8-C088-42B0-A7D1-9C41FE398DC2@microsoft.com...The bigger question is WHY? Do you have a new piece of hardware or software that required 64-bit? Can you get 64-bit drivers for all of your hardware, both internal (video cards, etc.) and external printers, scanners, web cams, keyboard and mice? "Ian Semmel" <anyone@rocketcomp.com.au> wrote in message news:07055983A63449A28B6229862BB17E39@DIMITY... (a) Can you upgrade from Vista-32 bit to 64-bit without trashing your disks ? (b) I have the 32-bit disks, can I get the 64-bit disks cheaper than buying a new set ? |
| | Re: Question about Vista 64-bit You've talked me out of it. I just thought that since I've got a 64-bit computer I should give it a whirl. But, after all the trouble I've had lately with Nvidia drivers, your advice is sound. From: Charles W Davis [mailto:Anthemwebs@lvcoxmail.com] The bigger question is WHY? Do you have a new piece of hardware or software that required 64-bit? Can you get 64-bit drivers for all of your hardware, both internal (video cards, etc.) and external printers, scanners, web cams, keyboard and mice? "Ian Semmel" <anyone@rocketcomp.com.au> wrote in message news:07055983A63449A28B6229862BB17E39@DIMITY... (a) Can you upgrade from Vista-32 bit to 64-bit without trashing your disks ? (b) I have the 32-bit disks, can I get the 64-bit disks cheaper than buying a new set ? |
| escape character question - hopefully an easy question | PowerShell | |||
| Vista question | Vista General | |||
| Re: Vista Question | Vista General | |||
| vista genral question and ultimate question | Vista General | |||
| Dual boot system question and family deal discount question | Vista General | |||
