| Guest | Vista issues after upgrading from 2000 Premium to Small Business 2 I just installed the Microsoft Office 2007 Small Business as an upgrade to Microsoft Office 2000 Premium on Windows Vista Home Premium. The installation seemed to go just fine, however, every time any office 2007 application (except Outlook which just 'magically' stopped doing it) opens I get "please wait while Windows configures Office Small Business 2007..." Excel gives me an error about stdole32.tlb (for me it only says stdole32.tlb and an ok button. Nothing about not being registered). Tons of articles on-line say that having two versions of Office installed on Vista might be causing the problem...so.....I uninstalled Office 2000 Premium and then ran the repair feature on the Office 2007 CD but the Office 2007 programs are still throwing up the "please wait" windows. As this takes 3 - 5 minutes every single time I try to open one of these programs, it is driving me BONKERS! Once I get past this installer problem, the programs seem to work fine. In several articles, it was recommended to run the cleanup utilitiy, however, on that page in the Microsoft Knowledge base it plainly states to not use it with Office 2007. Also, when I go into Set Default Programs in the Control Panel, the only one of the new Office 2007 programs that shows up is Outlook so it's obvious that Windows doesn't 'think' that the other programs (the ones throwing up the installer) are, in fact, actually installed. I would do a clean install of Office 2007 but I purchased the upgrade so I have to have Office 2000 already installed for it to work. If there's a problem with upgrading, you'd think that Microsoft would have come out with some sort of patch or, at the very least, a tech article that SOLVES the problem but I can't seem to find one. If anyone knows of a way to fix this issue, I would GREATLY appreciate your response. THANKS! (I've also posted this on the Microsoft Office discussion because I'm not sure exactly whether the problem is an Office 2007 issue or a Vista issue) |
| Guest | Re: Vista issues after upgrading from 2000 Premium to Small Business 2 "SouthernDancer23" <SouthernDancer23@discussions.microsoft.com> wrote in message news:21033BD8-528A-4BDC-9ACA-3AA9E7F7158A@microsoft.com... >I just installed the Microsoft Office 2007 Small Business as an upgrade to > Microsoft Office 2000 Premium on Windows Vista Home Premium. > > The installation seemed to go just fine, however, every time any office > 2007 > application (except Outlook which just 'magically' stopped doing it) opens > I > get "please wait while Windows configures Office Small Business 2007..." > Excel gives me an error about stdole32.tlb (for me it only says > stdole32.tlb > and an ok button. Nothing about not being registered). > > Tons of articles on-line say that having two versions of Office installed > on > Vista might be causing the problem...so.....I uninstalled Office 2000 > Premium > and then ran the repair feature on the Office 2007 CD but the Office 2007 > programs are still throwing up the "please wait" windows. As this takes > 3 - > 5 minutes every single time I try to open one of these programs, it is > driving me BONKERS! Once I get past this installer problem, the programs > seem to work fine. In several articles, it was recommended to run the > cleanup utilitiy, however, on that page in the Microsoft Knowledge base it > plainly states to not use it with Office 2007. > > Also, when I go into Set Default Programs in the Control Panel, the only > one > of the new Office 2007 programs that shows up is Outlook so it's obvious > that > Windows doesn't 'think' that the other programs (the ones throwing up the > installer) are, in fact, actually installed. > > I would do a clean install of Office 2007 but I purchased the upgrade so I > have to have Office 2000 already installed for it to work. If there's a > problem with upgrading, you'd think that Microsoft would have come out > with > some sort of patch or, at the very least, a tech article that SOLVES the > problem but I can't seem to find one. > > If anyone knows of a way to fix this issue, I would GREATLY appreciate > your > response. > > THANKS! > > (I've also posted this on the Microsoft Office discussion because I'm not > sure exactly whether the problem is an Office 2007 issue or a Vista issue) You might want to try this question in one of the Office newsgroups. -- Michael Solomon Backup is a PC user's best friend DTS-L.Org: http://www.dts-l.org/ |
| Guest | Re: Vista issues after upgrading from 2000 Premium to Small Busine Thank you Michael but I'm not very familiar with newsgroups and how they work. I'll try and figure them out if no one can answer my question here, however. Theresa > > You might want to try this question in one of the Office newsgroups. > -- > Michael Solomon > Backup is a PC user's best friend > DTS-L.Org: http://www.dts-l.org/ > > |
| Guest | Re: Vista issues after upgrading from 2000 Premium to Small Busine "SouthernDancer23" <SouthernDancer23@discussions.microsoft.com> wrote in message news:E1241D5D-33FB-4D6F-8CC0-B1D7A3ED0906@microsoft.com... > Thank you Michael but I'm not very familiar with newsgroups and how they > work. I'll try and figure them out if no one can answer my question here, > however. > > Theresa >> >> You might want to try this question in one of the Office newsgroups. >> -- >> Michael Solomon >> Backup is a PC user's best friend >> DTS-L.Org: http://www.dts-l.org/ >> >> Okay, you are in the communities, go to the following link: http://www.microsoft.com/communities...s/default.aspx Click the plus sign next to English, click the plus sign next to Office and Desktop Applications, in the list, you will find various Office Applications and a sub-heading specific to Office, click the plus sign next to Office and you will find a group specific to General Questions. If they can't help specifically in that group, they should be able to guide you as to how best to proceed or which group will offer the best help on this issue. -- Michael Solomon Backup is a PC user's best friend DTS-L.Org: http://www.dts-l.org/ |
| Guest | Re: Vista issues after upgrading from 2000 Premium to Small Busine Thank you again Michael!! I've headed over to that forum to try my luck! In the mean time, I've tried uninstalling both Office 2000 and Office 2007 and then only reinstalling Office 2007 but, now even my Outlook is launching the installer. I don't really believe that it completely uninstalled everything everything but I'm not comfortable or knowledgable enough in the registry to start manually removing and editing entries....oh well....so much for user friendly software! (grin) |
| | #6 (permalink) |
| Guest | Re: Vista issues after upgrading from 2000 Premium to Small Busine "SouthernDancer23" <SouthernDancer23@discussions.microsoft.com> wrote in message news:12CE8711-222C-40BA-8D24-EED60F7CCC11@microsoft.com... > Thank you again Michael!! I've headed over to that forum to try my luck! > In > the mean time, I've tried uninstalling both Office 2000 and Office 2007 > and > then only reinstalling Office 2007 but, now even my Outlook is launching > the > installer. I don't really believe that it completely uninstalled > everything > everything but I'm not comfortable or knowledgable enough in the registry > to > start manually removing and editing entries....oh well....so much for user > friendly software! (grin) You're welcome and they can probably help you with this of the uninstall as well. -- Michael Solomon Backup is a PC user's best friend DTS-L.Org: http://www.dts-l.org/ |
