| Guest | Display settings keep changing I have two monitors. I have a 19in Wide set to 1440x900 and a 10 in 4x3 set to 1280 x 1024. Every user is set that way. When I switch users it comes up with the resolutions changed to lower values. Why and how do I stop this. Is it drivers or Vista I wonder. The car is a Radeon 1400 PCI Express, One monitor uses the Digital out and the other the analog.' -- Posted via a free Usenet account from http://www.teranews.com |
| Guest | Re: Display settings keep changing Try this - go to -*Task*- -*scheduler*- and click on *-task scheduler library-* - *-'microsoft' (http://tinyurl.com/4gvo6f)-* - -*windows*- - -*mobile pc*- --*TMM*- - then right click and -*disable*-. Worked for me -- Hypnotiseme Posted via http://www.vistaheads.com |
| Display Settings - Enable or Disable Changing | Tutorials | |||
| changing display settings | Vista General | |||
| Changing Display Settings (Resolution mainly) through Safe Mode | Vista General | |||
| Changing display settings via registry | Vista hardware & devices | |||
| Changing display settings in Vista to solve STOP ERROR????? | Vista performance & maintenance | |||
