| | Help switching from 64bit to 32 bit I recently purchased a new laptop and it came pre-installed with Vista 64bit. However I'd prefer to run 32bit, how do I change? I do have the recovery DVD for Vista 32bit. Thanks for anyhelp. P.S. Step by step instructions would be best. |
| | Re: Help switching from 64bit to 32 bit Hi, Instructions should be included with your disks and are dependent on the system manufacturer as they generally vary greatly from a retail install. You can't simply convert or downgrade, the switch will require a clean installation of the 32 bit version, meaning all data and programs on the system will be gone. Data should be backed up to removable media, programs will need to be reinstalled from their original installation media. Your system manufacturer may provide a program recovery disk in addition to to system recovery disks. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "ChrisM930" <ChrisM930@discussions.microsoft.com> wrote in message news 2925DE5-CCA0-4EE4-94CE-569C2225DF12@microsoft.com...>I recently purchased a new laptop and it came pre-installed with Vista >64bit. > However I'd prefer to run 32bit, how do I change? I do have the recovery > DVD for Vista 32bit. Thanks for anyhelp. > > P.S. Step by step instructions would be best. |
| | Re: Help switching from 64bit to 32 bit On Tue, 7 Aug 2007 18:24:00 -0700, ChrisM930 <ChrisM930@discussions.microsoft.com> wrote: > I recently purchased a new laptop and it came pre-installed with Vista 64bit. > However I'd prefer to run 32bit, how do I change? I do have the recovery > DVD for Vista 32bit. Thanks for anyhelp. > > P.S. Step by step instructions would be best. Recovery CD/DVDs are not standard Windows items, and are created by the system manufacturer. How to use them varies with the manufacturer. You will need to consult your documentation, manufacturer's web site, or call them, to find out exactly how to proceed. -- Ken Blake, Microsoft MVP Windows - Shell/User Please Reply to the Newsgroup |
| | Re: Help switching from 64bit to 32 bit On Wed, 08 Aug 2007 16:03:00 -0700, "Ken Blake, MVP" <kblake@this.is.am.invalid.domain> wrote: >On Tue, 7 Aug 2007 18:24:00 -0700, ChrisM930 ><ChrisM930@discussions.microsoft.com> wrote: > >> I recently purchased a new laptop and it came pre-installed with Vista 64bit. >> However I'd prefer to run 32bit, how do I change? I do have the recovery >> DVD for Vista 32bit. Thanks for anyhelp. >> >> P.S. Step by step instructions would be best. > > >Recovery CD/DVDs are not standard Windows items, and are created by >the system manufacturer. How to use them varies with the manufacturer. >You will need to consult your documentation, manufacturer's web site, >or call them, to find out exactly how to proceed. In the past you just put the disk in and it asks if you are sure you want to wipe out the whole pc, the only option if you want to use the restore disks, and then formats the disk and restores the computer back to store bought condition. |
| | Re: Help switching from 64bit to 32 bit On Thu, 09 Aug 2007 12:37:48 GMT, f/fgeorge <ffgeorge@yourplace.com> wrote: > On Wed, 08 Aug 2007 16:03:00 -0700, "Ken Blake, MVP" > <kblake@this.is.am.invalid.domain> wrote: > > >On Tue, 7 Aug 2007 18:24:00 -0700, ChrisM930 > ><ChrisM930@discussions.microsoft.com> wrote: > > > >> I recently purchased a new laptop and it came pre-installed with Vista 64bit. > >> However I'd prefer to run 32bit, how do I change? I do have the recovery > >> DVD for Vista 32bit. Thanks for anyhelp. > >> > >> P.S. Step by step instructions would be best. > > > > > >Recovery CD/DVDs are not standard Windows items, and are created by > >the system manufacturer. How to use them varies with the manufacturer. > >You will need to consult your documentation, manufacturer's web site, > >or call them, to find out exactly how to proceed. > In the past you just put the disk in and it asks if you are sure you > want to wipe out the whole pc, the only option if you want to use the > restore disks, and then formats the disk and restores the computer > back to store bought condition. Yes, that's generally true. But I'm reluctant to advise anyone to do that without his reading the instructions first. There is nothing standard about a recovery disk, and there's no guarantee that all manufacturers do them the same way. -- Ken Blake, Microsoft MVP Windows - Shell/User Please Reply to the Newsgroup |
| 64bit PC MACHINE, X86 WINDOWS,CAN I have 32bit & 64bit vista partitions | General Discussion | |||
Unable to install 64bit NVidia drivers on Vista 64bit | Drivers | |||
| Upgrade from Home Premium 64bit to Ultimate 64bit - No 64bit Media | Vista installation & setup | |||
| Switching to 32bit Vista from 64bit Vista | Vista installation & setup | |||
| switching from 64bit to 32bit now then back to 64bit later | Vista installation & setup | |||
