Vista - Wireless gadget not working
Old 08-07-2007   #1 (permalink)
animusic
I have Windows Vista Ultimate and its great. I got a wireless gadget for my
laptop and it stoped working one day. I also have Yahoo! Gadgets and have a
wireless gadget in there and it works. I have tried many other wireless
gadgets and they don't work either. Is there any way to repair Windows
SideBar without repaing Windows Vista itself?
Old 08-17-2007   #2 (permalink)
John Bryntze
RE: Wireless gadget not working
All 3rd party gadgets are saved in
%userprofile%\appdata\local\microsoft\windows sidebar\gadgets in a sub folder
with the name of the gadget and a suffix .gadget
Control that the files there are correct and exchange them with newer if you
want.
Gadgets are mostly made up by text files (gadget.xml and gadetname.htm) so
you can in and check the code and verify.
Old 08-17-2007   #3 (permalink)
animusic
I read from the Gadget gallery that Virtual PC 2007 interferes with the
SideBar. I happen to have Virtual PC 2k7 installed on my computer. Is there
any way that I can keep VPC2k7 installed and make the gadget work?
Old 08-17-2007   #4 (permalink)
John Bryntze
See the gadgets as HTML, and I run Virtual PC 2007 and all my gadgets works.
Virtual PC reads the WiFi data and probably your gadget too, so it is more
likely there the problem is.
Use RegMon and FileMon + audit to find out how they conflict
> want.
Gadget Not working -- Please help me General Discussion
weather gadget not working General Discussion
weather gadget not working Vista General
Wireless gadget stopped working Vista General
Feed Headlines Gadget not working Vista General
