Vista - Taskbar gone wrong? Please help!
Old 08-08-2007   #1 (permalink)
Tom
hi, i bought a vista premium laptop on the 3rd of august and within the first
week there is already a problem. i heard vista was bad but this is
ridiculous. the taskbar doesnt work at all. if i minimise something, i cant
bring it back up i have to ctrl alt delete it and if i click anywhere on the
taskbar it just dings... please help? on xp there is a way to reset the pc to
an earlier date so i thought that might work with this but i dont know how to
do it... well... does anybody have a solution?
Old 08-08-2007   #2 (permalink)
drleeds
Re: Taskbar gone wrong? Please help!
I bought my laptop back in April and had the same problem for the
first month where the taskbar was useless, and in my case, had a
strange jumbled appearance where minimized items overlapped but were
un-clickable.
The problem in my case was the Firefox web browser. If I didn't use
it, the problem never happened.
Unfortunately, as you may have seen on another post, I also have
problems with the Internet Explorer version 7 web browser which have
not been resolved. You may want to try Opera or Safari as alternates
if you have the same problem as me where letters are dropped when
typing in a text box on a web page with Internet Explorer.
If you have not downloaded Firefox and have never used it on your
current laptop, then obviously this is not your problem. In that case
try this: disable all graphics goodies by setting to Windows Classic,
or something like that. Then, disable as many startup programs as you
can. Then disable browser add-ons. When you are finished, you may
solve the problem, but your computer will be no fun. Sorry, if I
sound a little bitter about the Vista experience
Actually, It is growing on me now. I hope they fix everything soon.
Old 08-08-2007   #3 (permalink)
Tom
> un-clickable.
Ok i will try that now =) thank you!
Old 08-08-2007   #4 (permalink)
Tom
> un-clickable.
no, it didnt work. thanks for trying to help though
Old 08-08-2007   #5 (permalink)
Andrew McLaren
"Tom" <Tom@discussions.microsoft.com> wrote ...
> first
> cant
> the
> to
> to
Hi Tom,
I don't have a solution for the specific problem you're seeing. But you
*might* be able to get some more info about the problem, this way:
- go to Start menu, Control Panel;
- click on System and Maintenance
- under Problem Reports and Solutions, click on View Problem History
- investigate any problems that are listed.
It could be something like Explorer hitting a memory access violation. You
can also use the "Check for new solutions" link to see if there is a hotfix
for the problem.
If the laptop is still only a couple of weeks old, it might still be under
warranty, you could return it to the vendor for support. What brand and
model is it?
Andrew McLaren
amclar (at) optusnet dot com dot au
Old 08-08-2007   #6 (permalink)
housetrained
"Tom" <Tom@discussions.microsoft.com> wrote in message
news:5502D098-FCA9-41B8-83F5-30B447767F5C@microsoft.com...
<snip>
> to
windows key - type restore - click on system restore.
John the West Ham fan
house.trained@virgin.net
housetrained@hotmail.com
Taskbar iconized folder buttons show the wrong little icon General Discussion
minimized tabs on taskbar wrong side? Vista General
Vista Home Premium - Taskbar clock permanently wrong Vista installation & setup
how to show taskbar button on the taskbar-plz don't think I am jok Vista performance & maintenance
WHat am i doing wrong Vista hardware & devices
