| Guest | Vista Sound Recorder Does Not Record I can't get the Vista Sound Recorder to record using my microphone (ASUS Array Mic & another older model). I setup the mike in Control Panel/Manage Audio Devices everything seems to setup fine and I can see the volume level fluctuate when I do the config test. I'm using onboard sound (no sound card) with M2N-SLI Deluxe However, when I open the Vista Sound Recorder and start recording, the volume meter bar(window) never moves/displays at all and when I play the saved recording there is no sound. -- megatonone |
| Guest | Re: Vista Sound Recorder Does Not Record The same here - exactly! Scroll down to the thread "Microphone Vanished!" - 8th August 06.22 and you will see that our problem is not at all uncommon. I have even installed the freebie recorder Audacity but I still get silence. I refuse to believe that everybody's adapter must be malfunctioning. It must be a Vista issue. Greg "megatonone" <megatononetwo@gmail.com> wrote in message news 62C1E1D-A5B3-48F5-AE87-C76CA2BB1311@microsoft.com...>I can't get the Vista Sound Recorder to record using my microphone (ASUS > Array Mic & another older model). I setup the mike in Control Panel/Manage > Audio Devices everything seems to setup fine and I can see the volume > level > fluctuate when I do the config test. > > I'm using onboard sound (no sound card) with M2N-SLI Deluxe > > However, when I open the Vista Sound Recorder and start recording, the > volume meter bar(window) never moves/displays at all and when I play the > saved recording there is no sound. > > -- > megatonone |
| Guest | RE: Vista Sound Recorder Does Not Record Err...ah It works fine now that I installed the latest sound driver formy mobo...I went to ASUS site and there was a newer version of my sound and now all is just peachy ...I should have thought a bit more before posting ![]() -- megatonone "megatonone" wrote: > I can't get the Vista Sound Recorder to record using my microphone (ASUS > Array Mic & another older model). I setup the mike in Control Panel/Manage > Audio Devices everything seems to setup fine and I can see the volume level > fluctuate when I do the config test. > > I'm using onboard sound (no sound card) with M2N-SLI Deluxe > > However, when I open the Vista Sound Recorder and start recording, the > volume meter bar(window) never moves/displays at all and when I play the > saved recording there is no sound. > > -- > megatonone |
| Guest | Re: Vista Sound Recorder Does Not Record Me too! )-: However, the preloaded Vista drivers are obviously garbage. Greg "megatonone" <megatononetwo@gmail.com> wrote in message news:29F2DD5F-5EC9-45B3-9159-6E2FC5DA3E96@microsoft.com... > Err...ah It works fine now that I installed the latest sound driver> for > my mobo...I went to ASUS site and there was a newer version of my sound > and > now all is just peachy ...I should have thought a bit more before> posting ![]() > -- > megatonone > > > "megatonone" wrote: > >> I can't get the Vista Sound Recorder to record using my microphone (ASUS >> Array Mic & another older model). I setup the mike in Control >> Panel/Manage >> Audio Devices everything seems to setup fine and I can see the volume >> level >> fluctuate when I do the config test. >> >> I'm using onboard sound (no sound card) with M2N-SLI Deluxe >> >> However, when I open the Vista Sound Recorder and start recording, the >> volume meter bar(window) never moves/displays at all and when I play the >> saved recording there is no sound. >> >> -- >> megatonone |
| Sound Recorder In Vista | Vista General | |||
| Trying to Use Sound Recorder to Record T.V. Theme Music | Vista hardware & devices | |||
| Vista vs. XP Sound Recorder | Sound & Audio | |||
| Sound Recorder (downgraded) in Vista | Vista General | |||
| How to record sound clips or music using the sound recorder? | Vista music pictures video | |||
