Vista Tutorial - Problems after upgrade from home basic to home premium
Old 08-09-2007   #1 (permalink)
Rob
Guest
I upgraded the other day from home basic to home premium using the windows
any time upgrade disk that came with my machine (Dell Inspiron 9000)
Since then I have no sound and if i hover of the sound icon in the task bar
I get the message "No audio output device is installed" Sure enough if I look
in device manager there is no mention of anything to do with sound.
Also I get a message from Mcafee security suite saying that my computer is
not protected, if I open it pretty much all the features are disabled and if
I try to re-enable them or click "Fix now" the Mcafee window flashes a few
times but then hangs or crashes or simply fails to "Fix" the problems.
Any ideas?
Old 08-09-2007   #2 (permalink)
Qfreed
Guest
RE: Problems after upgrade from home basic to home premium
Sounds to me like Windows Premium dropped a driver or failed to recognize
your sound card. I wanted to address your second problem, however. I use
McAffee security suite also and have had problems using their "fix" button
locing up my system. I just wanted to mention that the message you get about
your computer not being protected may still haunt you even if you get its
firewall, virus checker, spyware checker, etc. enabled. McAffee offers other
Premium options like E-mail scanning, or the like, that they want you to buy.
Therefore, even if you get the features you want (I suggest that you use
Windows firewall and not theirs as theirs isn't as compatible with other
programs) enabled you will still get that message inferring that you need to
buy their premium package to be fully protected. It does go away at some
point because I no longer see it and I never bought the premium package.
qfreed
> Any ideas?
Old 08-10-2007   #3 (permalink)
Rob
Guest
I think I may try uninstalling Mcafee and re-installing. See what happens!
As for the sound card it also doesnt even recognise it if I scan for new
harware. Strange!
> qfreed
> > Any ideas?
Old 08-10-2007   #4 (permalink)
Julian
Guest
Re: Problems after upgrade from home basic to home premium
"Rob" <Rob@discussions.microsoft.com> wrote in message
news:2B33A676-0EAC-422A-A937-1037459C16CA@microsoft.com...
I wouldn't reinstall it if I were you since it is in the frame
for many email problems on Vista systems.
Avast (or AVG) (free) is a much safer products...
http://www.avast.com/eng/avast_4_home.html
Check microsoft.public.windows.vista.mail for a litany
of McAfee and , even moreso, Norton related problems.
> harware. Strange!
>> recognize
>> use
>> button
>> about
>> other
>> buy.
>> to
>> qfreed
>> > windows
>> > bar
>> > I look
>> > is
>> > and if
>> > few
>> > Any ideas?
how to upgrade from Vista Home Basic to Home Premium? Vista General
Re: Anytime Upgrade from Vista Home Basic to Home Premium Vista installation & setup
Home Basic to Home Premium (Without Upgrade Anytime DVD) Vista General
Upgrade from Vista Home Basic to Home Premium Vista General
Upgrade from Home Basic to Home Premium question. Vista installation & setup
