Vista Forums Home Join Vista Forums Donate Windows 7 Forum Vista Tutorials Tags
Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks.
Default Connection
LinkBack Thread Tools Display Modes
Old 08-09-2007   #1 (permalink)
New Orleans Novice
Guest
Default Connection
Default Connection
Using Vista home on a new HP PC. After connecting to DSL broadband it works
fine. Using a wireless router. 2 HP PC's are using a wireless USB adapter.
But when both PC's are turned off, then restarted after a lightening storm,
they both load up to a default DIAL Up connection.
It there a way to make the Always on DSL broadband connection load up at
startup ?
Thanks from New Orleans
Old 08-09-2007   #2 (permalink)
Mark Dormer
Guest
Re: Default Connection
Open Internet Explorer
Select Tools--Internet Options
On the Connections tab make sure "Never dial a connection" is checked
Regards
Mark Dormer
www.swiug.org.au
"New Orleans Novice" <novice@katrinafamilysupport.com> wrote in message
news:OgblScp2HHA.2752@TK2MSFTNGP06.phx.gbl...
> Default Connection
> works fine. Using a wireless router. 2 HP PC's are using a wireless USB
> adapter.
> storm, they both load up to a default DIAL Up connection.
> startup ?
Old 08-09-2007   #3 (permalink)
New Orleans Novice
Guest
Thank you it worked
Display Modes
Have lost default network connection on laptop Wlybggr Vista networking & sharing 1 04-04-2008 09:59 AM
Set my Wireless as Default Connection celeste Vista networking & sharing 1 11-03-2007 12:09 PM
Default Connection New Orleans Novice Vista hardware & devices 2 08-09-2007 10:54 AM
Default Connection New Orleans Novice Vista installation & setup 2 08-09-2007 10:54 AM
What's the .exe or .dll for the default icon for a dial-up connection? Andrew Aitchison Vista General 6 05-25-2007 08:22 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
