| | Problem with missing drive letter I used partitioning software (Partition Commander) in Vista to adjust the size between two partitions on HD0. It failed during the operation, however. I was able to load Windows using their recovery CD and found that the physical changes hadn't been committed. Unfortunately, it removed the drive letter from the Vista Windows partition. I originally was dual-booting with XP on 'C' and Vista on 'Z' (same HD, two partitions). I stopped using XP long ago so now I'm ready to shrink 'C' down and give 'Z' the extra space. However, now when I load Vista it no longer assigns drive letter 'Z' to it, it gets the next sequential fixed drive letter ('G'). As a result I can't load any profiles or do anything that has a hard coded registry entry (i.e. z:\windows...). I cannot start the Computer Management console to assign the drive letter because it points to a registry entry of "z:\windows...". I also can't change the value in the registry and make all hard coded entries point to 'G'. I assume it's a Windows Catch 22 - I can't modify the value because it's in use or because Windows thinks it knows better than me and I'll screw it up by renaming it. I tried using batch search and replace utilities but they won't work either (and I am the admin, so it shouldn't be a permissions issue). So, how can I assign a drive letter when the function within Vista won't work or change all the registry entries, especially those specific to Windows, to use the new drive letter? If the latter route works, then I would use Vista to permanently assign the drive letter. And I'd use Vista to size the partitions, since I now know that's a new feature in Windows. |
| Flash Drive has no drive letter... Not in Disk Management | Vista hardware & devices | |||
| Phantom CD Drive after reassigning Recovery Partition drive letter | Vista installation & setup | |||
| Missing drive letter causing big Windows problems | Vista hardware & devices | |||
| Drive Letter Problem - Vista Installation | Vista installation & setup | |||
| USB drive letters and mapped drive letter issues | Vista hardware & devices | |||
