Vista Tutorial - Vista Print Spooler problems
Old 08-10-2007   #1 (permalink)
Richard
Guest
I am running Vista business on a laptop with a Magicolor 2300DL set as
a TCP/IP printer which seems to remain as a local printer. Whn I send
a print job to the 2300, it takes a longer time for the job to print,
whereas in XP it printed quite rapidly. I tried stoppingand
restarting the print server, completing deleting the printer and
driver, and playing with the print managment program which is now on
my Quick Launch. When the job prints, it is OK, but it just takes a
long time to print...
Richard
Old 08-10-2007   #2 (permalink)
Mike
Guest
Re: Vista Print Spooler problems
In article <1186775947.399644.148270@m37g2000prh.googlegroups.com>,
A TCP/IP printer *is* a "local" printer as far as Windows is concerned.
It prints to a "local" TCP/IP port. It's not a "shared printer"
attached to another machine. You print directly to the printer, and
not to the "Print Queue" of the shared printer machine.
As for your speed issue, I have no idea. I have an old HP Laser Jet 4
Plus here that works at the same speed in Vista, XP and OS X. It's an
IP printer that is a "local" printer to all Windows machines.
Mike
How I fixed my Vista Print Spooler Problems Vista print fax & scan
Print spooler problems in Vista Home Premium 64bit Vista print fax & scan
HOw do I start the print spooler so I can install my print drivers? Vista installation & setup
Print Spooler problems, tried all the fixes listed and no dice... Vista print fax & scan
Print Spooler - Vista Vista print fax & scan
