Vista - How to reset USB port memory?
Old 08-11-2007   #1 (permalink)
Alain Caillet
After connecting a USB phone handset, Vista loaded the driver then
requested a reboot. I then realised that only the USB microphone device
showed up in Control panel/Sound/Recording menu. The USB speaker device
didn't register.
I plugged the handset in an other USB port. Driver loaded, did the
requiered reboot and this time both microphone and speaker are listed in
as USB sound device.
If I return the uSB hanseet to the first USB port, it has memorise the
driver setting and it still recognize only the microphone. How can I rest
the "driver memory" for this USB port. I imagine it's somewhere in the
registry but where ?
Thanks in advance
Alain Caillet
Old 08-11-2007   #2 (permalink)
Cal Bear '66
Re: How to reset USB port memory?
Plug another, different type of device (USB memory stick, etc.) into the
original USB port?
I Bleed Blue and Gold
GO BEARS!
"Alain Caillet" <AA-Caillet@wanadoo.fr> wrote in message
newsp.twwhygkgmqxr1t@news.msnews.com...
> After connecting a USB phone handset, Vista loaded the driver then requested
> a reboot. I then realised that only the USB microphone device showed up in
> Control panel/Sound/Recording menu. The USB speaker device didn't register.
> I plugged the handset in an other USB port. Driver loaded, did the requiered
> reboot and this time both microphone and speaker are listed in as USB sound
> device.
> If I return the uSB hanseet to the first USB port, it has memorise the driver
> setting and it still recognize only the microphone. How can I rest the
> "driver memory" for this USB port. I imagine it's somewhere in the registry
> but where ?
> Thanks in advance
> Alain Caillet
Old 08-11-2007   #3 (permalink)
Alain Caillet
> original USB port?
Thanks Cal Bear, I did think of it. I plugged a mouse ... mouse driver
loaded, mouse worked but handset is still remembered as having only a
microphone...
Too bad didn't work :-(
Alain Caillet
Old 08-12-2007   #4 (permalink)
John Barnes
Go to Device Manager, find the offending port and delete the driver, reboot
and you should have the USB driver installed, then plug in your device. If
you are going thru a hub, that may be your problem.
newsp.twwwejp7mqxr1t@news.msnews.com...
>> original USB port?
> microphone...
> Alain Caillet
reset usb port General Discussion
reset port 00 error Vista hardware & devices
Free Physical Memory drops to Zero right after reset Vista General
USB port remembers drivers previously loaded for plugged-in devices. Can it be reset? Vista hardware & devices
windows vista login as admin causes memory dump and reset Vista General
