| | Dell Axim X51v has stopped syncing with WMDC 6.1 running on Vista Home Premium As of last Monday or so, my Ax stopped syncing with my laptop / Vista Home Premium. Up until that time it was working like a charm -- better than any version of ActiveSync. I installed nothing or changed nothing on the Axim. AAMOF, I did not even remove it from its cradle other than to soft-reset. The sync would fail with the message "Synchronization cannot be started because you are not able to log on to the network and access information. Restart your desktop computer and synchronize again. If the problem persists, contact your network administrator." I have restarted the laptop and the Axim many times and I have also re-installed the drivers. I have checked and WMDC and the WMDC Host Services are both running. The laptop and is up to date as is the Axim. I went to the WMDC Home page and ran through the troubleshooting option that was closes to my issue -- no joy. I am able to browse the Axim from the laptop and also browse the Internet from the Axim. So there is a viable connection via the USB cable and cradle. I can also access the Internet and the intranet in my house, so I have no clue what network this message is referring to. I deleted the partnership and re-established a new partnership and right off the bat the same message came up after the sync failed. I am using MS Office Professional 2003 on the laptop and Pocket Informant 2007 Rev.4 on the Axim. McAfee ===== Now this bit of information might assist the diagnosis. Around the same time, McAfee downloaded an update and corrupted itself. Details of this SNAFU can be found in the Announcement here -- http://ts.mcafeehelp.com/?siteID=1 Well this led to various components of McAfee not working and despite my using their cleanup tool and patch, McAfee could not be repaired and after I uninstalled it I could not reinstall it. I have since installed Windows Live OneCare on a 90-day trial and that installed easily and is working perfectly. So much for McAfee. Firewall ===== During the course of my many searches on the Internet I cam across suggestions that the firewall might be the issue. I thought of this also, but then figured the firewall would not allow browsing or a pass-through to the Internet as previously described. Still I have verified that I only have 1 firewall active -- the Windows Live OneCare firewall (Vista's firewall is turned off) -- and that firewall has been set up to explicitly allow ActiveSync and WMDC. Technical Support ============== I called MS Tech Support and their WMDC team only works M-F, and besides, the call might cost me since this sort of thing is supposed to be handled by the device (Axim) manufacturer (Dell). Dell's web page explicitly says that free support only extends to hardware-related issues and issues such as this woudl also cost me money. So I am left in the lurch except for (hopefully) the experts in these NGs. Services or a Registry Hack ===================== I suspect that the solution lies somewhere in the enabling of a service or in hacking the registry. However I am not sure what this might be. If not too tired from reading this epistle, can anyone help? Regards, Wayne Moses Houston, Texas |
| | Re: Dell Axim X51v has stopped syncing with WMDC 6.1 running on Vista Home Premium At 11 Aug 2007 22:23:10 +0000 Wayne Moses wrote: > Now this bit of information might assist the diagnosis. Around the > same time, McAfee downloaded an update and corrupted itself. Details > of this SNAFU can be found in the Announcement here -- > http://ts.mcafeehelp.com/?siteID=1 > > Well this led to various components of McAfee not working and despite > my using their cleanup tool and patch, McAfee could not be repaired > and after I uninstalled it I could not reinstall it. Let me preface this with the information that I'm not a Vista/WMDC user, so take any advice of mine with several grains of salt. Having said that, I don't believe in coincidences- if this McAfee snafu happened around the same time, it's extremely likely to be the culprit. However... > I have since installed Windows Live OneCare on a 90-day trial and > that installed easily and is working perfectly. So much for McAfee. Are you sure about the timeline here- did the error start before or after the OneCare install? Others have posted that they've had to manually open the OneCare firewall to let WMDC work if OneCare was installed after WMDC. So we probably need to figure out if the sync problem occured before OneCare to place the blame on McAfee or OneCare. If you did have the troublebefore, then McAfee might not be completely uninstalled, and manually removing all McAfee references from the PC's registry might be worth a try, followed by a reboot (insert all "dangers of modifying your registry" disclaimers here.) The fact that McAfee won't reinstall is a good indicator it's still messing up the works somehow. If you're positive the problem didn't crop up until after OneCare was installed, you might try uninstalling/reinstalling WMDC so OneCare "sees" it and allows you to let it through the firewall, or search the microsoft.public.pocketpc.activesync NG for a post about the four WMDC services to manually configure OneCall to let through. (There was a thread about this maybe a month ago, IIRC.) Best of luck- tracking down a sync problem is a b*tch, partially because no one wants to reproduce your issue on their own PCs just in case! ;-) -- "I don't need my cell phone to play video games or take pictures or double as a Walkie-Talkie; I just need it to work. Thanks for all the bells and whistles, but I could communicate better with ACTUAL bells and whistles." -Bill Maher 9/25/2003 |
| | Re: Dell Axim X51v has stopped syncing with WMDC 6.1 running on Vista Home Premium Hello Todd, Thanks for responding. TA> Having said that, I don't believe in coincidences- if this McAfee TA> snafu happened around the same time, it's extremely likely to be the TA> culprit. However... I have not at all ruled that out, espeically since I cannot be sure if the McAfee SNAFU occurred before or after the Axim stopped syncing with the laptop. All I can say is they happened about the same time. TA> Are you sure about the timeline here- did the error start before or TA> after the OneCare install? Absolutely certain it was before the OneCare install. I was having the two issues at the same time -- the lack of synchronicity between Axim and laptop, and the antivirus software problem. Since the latter was more important than the former, I concentrated on that until I managed to get the laptop to a point where it is no longer vulnerable and I can concentrate on the Axim sync problem. Incidentally, after I uninstalled McAfee and before settling on trying OneCare, I tried installing the trial version on Norton Antivirus 2007. What a joke. It would not activate so I could not even get it to install properly let alone work. I called their Tech Support and the chap I online chatted with said essentially that I would not have this problem with the purchased version! I asked him if he was saying that the trial version was useless then, and he said yes! Still desperate for protection, I bought it from WalMart and installed it -- same issue ... would not activate. So I uninstalled, ran its cleanup tool and checked the Registry personally. That is when I decided to look at OneCare. TA> Others have posted that they've had to TA> manually open the OneCare firewall to let WMDC work if OneCare was TA> installed after WMDC. Yeah, I read that, but doesn't apply in this case since I had the same problem before OneCare. TA> If you did have the troublebefore, then McAfee might not be TA> completely uninstalled, and manually removing all McAfee references TA> from the PC's registry might be worth a try, followed by a reboot TA> (insert all "dangers of modifying your registry" disclaimers here.) Did that. More than once. After each attempt. TA> The fact that McAfee won't reinstall is a good indicator it's still TA> messing up the works somehow. That is my feeling .... the ghost of McAfee .... actually I think it is all gone but before going, it screwed some setting or the other. That is what I believe is causing this problem. TA> Best of luck- tracking down a sync problem is a b*tch, partially TA> because no one wants to reproduce your issue on their own PCs just TA> in case! ;-) I agree. Funny enough, I had it with ActiveSync, and that is why I upgraded to Vista .... just so I had WMDC, *despite* what some people said about WMDC at the time. I had a bear of a time getting Vista to see my Axim, and even had the MS Research Department (like level 3 tech support) call me daily trying this and trying that, when all I wanted was a Registry tweak that would get the two talking. Eventually I solved it on my own, after researching and all it took was 5 minutes. I shared this fix with him and he was grateful. Now ask me if I remember what it was! Anyway ... thanks for your help. I am hoping that someone else who might have had a similar problem with this error knows what the fix is. Regards, Wayne Moses Houston, Texas |
| | Re: Dell Axim X51v has stopped syncing with WMDC 6.1 running on Vista Home Premium At 12 Aug 2007 01:20:44 +0000 Wayne Moses wrote: > Anyway ... thanks for your help. I am hoping that someone else who > might have had a similar problem with this error knows what the fix is. Good luck! Posts like yours are why my Vista Upgrade package still sits in my desk unopened! (To be fair, I think I ran Win98SE for at least two years after XP came out, so I figure I'll give Vista a good year or two before I take the plunge!) I keep telling myself at my next Activesync disaster (and we all know there will be one eventually!) I'll just give in and get a hosted Exchange account for $7/month (or try Emoze) for my PIM data and "sync" my files manually with File Explorer over Wi-Fi! -- "I don't need my cell phone to play video games or take pictures or double as a Walkie-Talkie; I just need it to work. Thanks for all the bells and whistles, but I could communicate better with ACTUAL bells and whistles." -Bill Maher 9/25/2003 |
| | RE: Dell Axim X51v has stopped syncing with WMDC 6.1 running on Vista Mine also stop working. Basically everybody has or will have same problem. "Wayne Moses" wrote: Quote: > As of last Monday or so, my Ax stopped syncing with my laptop / Vista Home > Premium. Up until that time it was working like a charm -- better than any > version of ActiveSync. I installed nothing or changed nothing on the Axim. > AAMOF, I did not even remove it from its cradle other than to soft-reset. > > The sync would fail with the message "Synchronization cannot be started because > you are not able to log on to the network and access information. Restart > your desktop computer and synchronize again. If the problem persists, contact > your network administrator." > > I have restarted the laptop and the Axim many times and I have also re-installed > the drivers. I have checked and WMDC and the WMDC Host Services are both > running. The laptop and is up to date as is the Axim. I went to the WMDC > Home page and ran through the troubleshooting option that was closes to my > issue -- no joy. > > I am able to browse the Axim from the laptop and also browse the Internet > from the Axim. So there is a viable connection via the USB cable and cradle. > I can also access the Internet and the intranet in my house, so I have no > clue what network this message is referring to. > > I deleted the partnership and re-established a new partnership and right > off the bat the same message came up after the sync failed. > > I am using MS Office Professional 2003 on the laptop and Pocket Informant > 2007 Rev.4 on the Axim. > > McAfee > ===== > > Now this bit of information might assist the diagnosis. Around the same time, > McAfee downloaded an update and corrupted itself. Details of this SNAFU can > be found in the Announcement here -- http://ts.mcafeehelp.com/?siteID=1 > > Well this led to various components of McAfee not working and despite my > using their cleanup tool and patch, McAfee could not be repaired and after > I uninstalled it I could not reinstall it. > > I have since installed Windows Live OneCare on a 90-day trial and that installed > easily and is working perfectly. So much for McAfee. > > Firewall > ===== > > During the course of my many searches on the Internet I cam across suggestions > that the firewall might be the issue. I thought of this also, but then figured > the firewall would not allow browsing or a pass-through to the Internet as > previously described. > > Still I have verified that I only have 1 firewall active -- the Windows Live > OneCare firewall (Vista's firewall is turned off) -- and that firewall has > been set up to explicitly allow ActiveSync and WMDC. > > Technical Support > ============== > > I called MS Tech Support and their WMDC team only works M-F, and besides, > the call might cost me since this sort of thing is supposed to be handled > by the device (Axim) manufacturer (Dell). Dell's web page explicitly says > that free support only extends to hardware-related issues and issues such > as this woudl also cost me money. So I am left in the lurch except for (hopefully) > the experts in these NGs. > > Services or a Registry Hack > ===================== > > I suspect that the solution lies somewhere in the enabling of a service or > in hacking the registry. However I am not sure what this might be. > > If not too tired from reading this epistle, can anyone help? > > Regards, > Wayne Moses > Houston, Texas > > > |
| | #6 (permalink) |
| | RE: Dell Axim X51v has stopped syncing with WMDC 6.1 running on Vista Hello Raymond, R> Mine also stop working. Basically everybody has or will have same R> problem. This is a really old thread .... Since that time, I have had no problems at all with synching. I finished my 90 day trial of Windows Live OneCare and was pelased enough to buy it. installed it today. McAfee is gone. Too much of a PITA. Regards, Wayne Moses Houston, Texas |
| Dell Axim x51v and Sync Center Problem | Vista General | |||
| Dell Axim X51v won't sync? | Vista General | |||
| Vista home sync center just stopped working with DELL Axim | Vista General | |||
| Dell Axim X5 PPC Users - WMDC Help! | Vista General | |||
| Dell Axim X51v | Vista hardware & devices | |||
